I use the MiniDSP Flex/digital as volume control and parametric equalizer in my 2.2 audio system, feeding 2 channel Toslink into the DAC. Now my DAC is an RME ADI-2 DAC, which has digital volume control and PEQ of its own. Yet, the MiniDsp setup with the exact same filter (a simple low shelf-filter) sounds significantly cleaner and overall more integrated and natural. The difference is clearly audible. I identified the correct setup 7 out of 7 times in a blind listening test. Note that since all takes place in the digital realm the output volume of both setups is exactly equal so that can’t explain this result.
Possibly the PEQ output of the MiniDSP and RME differ very slightly, but I doubt that could explain what I hear. I personally think PEQ processing inside the RME produces electrical noise which somehow distorts the analog output. The MiniDSP’s optical output galvanically isolates it from the DAC so electrical noise can’t get into the DAC. Hence the better sound quality.
Anyway, though I'm generally very pleased with my MiniDSP unit, I also have a few issues. Firstly, the USB input is very finicky regarding the used USB cable. When I use the cable that is provided with it, streaming audio from a MacMini works fine, but if I use a cable that is 10 cm (or more) longer (which I used with various other USB interfaces without problems) it loses connection after a few seconds. A shorter cable again works fine. Does anyone recognize this? It makes me wonder about the long term reliability of the unit’s USB interface..
Secondly, the input selection (USB, Toslink, SPDIF, Analog, Bluetooth) requires 2 presses of the control knob and resets after just 1 second which is very annoying if you didn’t make your selection yet (you must then again press the control 2 times and make a selection within a second). I would prefer input selection after one press of the control, staying active for at least 5 seconds.
Third, it would be nice if there was a setting to disable the automatic dimming of the unit’s display, so the display would stay on.
Maybe some of these points can be addressed in the next software update
