Nitrium
I also think the SA-1's z-low and z-hi is really dumb, should have been a gain switch, also they should have added another gain stage.
What is that, exactly?
It changes the output impedance of the headphone out, its supposed to be for 600Ohm headphones and stuff.
you want low always, unless you doing like 600 or 800ohm headphones.
OK so, far sounds amazing, but lacking in power, thought the Susvara would run good on this headphone, the A90 pushes it better as of right now.
I flipped the switches to the left, all of them to the left for gain, then I have it on Z-Low.
Does that sound correct?
H-z can be used for 150ohm and above
H-z is to change the output impedance of the headphone output from 1.4 to 10 I think it is. I don't see why you would want to do that unless it was to mess with the sound or to use 600 ohm headphones or something.
I have tested a number of headphones ranging from 60-300ohm, they all sound a lot worst on Hi-Z muddy. You want an output impedance of 2 or less for the vast majority of headphones was my understanding.
What dac are you using at 6.8v? I have tried, the new SMSL dac the 800 dollar one, its little brother su-9, the RME-ADI2 dac fs, and the Matrix MQA dac. IDK what voltage any of them are putting out, I would imagine around 4-5 volts.
I used SMSL M500.
Your RME-ADI2 can output 6.9-7V
then SU-9 have 5.3V
Matrix have 4.4V
So if you can try RME-ADI2 with max output and check if that give better sence of control to such HE6se also try use jumper to bypass the DC cab .
I am using the SMSL M400 with the SA-1 at the moment, volume is on 80, I think the m400 does 5.7V. I should try the RME again, what's this jumper bypass? That sounds interesting... I am using the Susvara's, same thing I supposes, still stupidly hard to power.
I can listen with them off the SA-1, its just the gain is not high enough so the volume has to go all the way up to 3 quarters, maybe a little higher for it to be loud enough for me. Has a little less power then my jot2, and a90 I think.
I loaned my SA-1 to a friend and he try it with Arya, he listened with High Gain @ 2 o'clock but he used SU-8 v2 which only output 4V and you need 4.4V XLR to get full power. he compared it to THX 789 and prefer SA-1 a lot to THX.I am looking for an amp that pairs well with my Hifiman Arya, a planar, 35ohm and 90db.
I would really like to hear from any SA-1 owners - how much volume range are you getting with your headphones? Are you able to get up around 12 o'clock?
With this trend of ever-greater output power, I really want to avoid a situation where I am only using 15 or 20 percent of the volume range.
Thanks!
Can someone elaborate on why you can have an AMP that does 3W but tops out on volume really low.
Like can have 2 different amps that does 3Watts but have different current and voltage ratings?
I bought the SA-1 today with their discount. But I don't have Jot 1.
Looks like their website is showing discounted prices across the board.Who's discount are you referring to; thanks?
