I think I understand what you are referring to but doubt that simply lowering the x-over frequency between bass and midrange could cure that. And even if so, it would come at a cost ...
The biggest impact of a lower crossover point would be higher load for the MF driver. Even if you invest extra money into increased excursion and power handling you'd end up with a higher moving mass. And the Uni-Q will work the better, the lower the cone excursion.
I still agree. It's why I went for this setup:
LS50 Meta with stereo Lyngdorf BW-2 subs, crossed at 200 Hz LR4 by the Lyngdorf TDAI-1120. Sounds great to my ears. It better should, list price (including stands) is actually even a tiny bit above LS60 Wireless. There are some cons but of course also a number of pros compared to LS60.
However, the biggest con of both setups is that neither will allow the integration of a KEF R6 Meta, which is the topic of this thread. I feel guilty.
@Descartes: Sorry, I can't. I'm living over here. You are more likely to find the solution than I am. Shipping costs for speakers will render any import attempts pointless.
for movies, wall of sound may be preferable to point source. Kef R2c may be the cheapest way to get thereListening to the R11 is the easiest way to tell since it has dual woofers flanking the UniQ, it's more like a wall of sound instead of a point-source like the LS50
The Horizontal plot looks like The Scream. ;-)
I asked the dealer about matching the R6 Meta as center with my Reference 3 Meta speakers and they don't recommend it. They obviously recommended going with the Reference 2 or 4, for a better match.
- aluminium drive units are the exact same size on both
- crossover frequencies of the R6 Meta are 500 Hz and 2.4 kHz
- crossover frequencies of the Reference 3 Meta are 450 Hz and 2.1 kHz
What do you think? Would it be that bad of a combination?
R6 Meta (cm, not inch!):Does anyone know what the back panel of the R6 Meta & R2 Meta is like? Where are the crossovers mounted and how thick is the material? I am considering wall mounting these as surrounds.
These are mounts I am considering:
Speaker wall mount
Multi-purpose wall mount for speakers with large wall plate for heavy speakers. The mounted speaker can be swiveled to the sides and tilted up to 30°. Easy mounting by convenient hooking in and screw…www.k-m.de
Adapter panel 1
Universal Mounting Bracket vertical, large with the following mounting templates: 69,9 x 127 mm - M8 50,8 x 107,9 mm - M6 62 x 47 mm - M6 70 to 76,2 mm - M6www.k-m.de
Adapter panel 2
Universal Mounting Bracket horizontal, large with the following mounting templates: 127 x 69.9 mm - M8 107.9 x 50.8 mm - M6 70 to 76.2 mm - M6www.k-m.de
You can always try the R6 and if you don’t like it upgrade to the referenceI asked the dealer about matching the R6 Meta as center with my Reference 3 Meta speakers and they don't recommend it. They obviously recommended going with the Reference 2 or 4, for a better match.
These AVR can’t drive 4 Ohm speakers very well!I'm having some clarity issues with the R6, sometimes I have to turn on subtitles to understand speech.
I have a Denon x4800h now, I'm using its internal amps to power all the 5 KEFs, including the R6 center. Previously I had an external stereo amp connected to the pre-outs of the Denon to drive the FR/FL, the center had slightly better clarity back then. Could be because the Denon had to drive only the center and the surrounds.
I am wondering if it's because of the lack of external amplification currently or there are other factors (DAC quality, etc.).
So the lack of power could easily explain this clarity issue?These AVR can’t drive 4 Ohm speakers very well!
Clearly, it compares well even to my 12" p/a drivers. Of course they will fall down the cliff at some point, but until that, what else to ask for?!What a beast the 6.5" woofer in the R6 meta is...What a beast the 6.5" woofer in the R6 meta is..
i just a bit confused, because the R6 is tuned to <not make subbass> yet i found the bass distortion very similar if not equal to my R7Clearly, it compares well even to my 12" p/a drivers. Of course they will fall down the cliff at some point, but until that, what else to ask for?!
Thank you for your review, I think a R6 is in my future. It’s too bad they don’t make it in blue like the R3 Meta they look sweet!Hi, again. This time, it's KEF's R6 meta.
Impedance
View attachment 299595View attachment 299596
Frequency Response
It's pretty flat except for some of the HF above 10 kHz.
The bass extension is 70.7 Hz (-6 dB) with -14dB/oct slope.
Nearfield Measurements
Directivity
View attachment 299599View attachment 299600View attachment 299601
Overall, it's a very smooth and well-controlled Directivity.
Beamwidth
View attachment 299603View attachment 299604
Narrowest around 5 kHz.
However, this is only a marginal difference that only appears when strictly compared to Reference 2 meta.
Polar plot
Due to the chunky mass of these speakers and the horizontally placed units, you can see that most of the sound is only radiating forward.
Beautiful attenuation all around, and uniformly controlled HF directivity.
Total Harmonic Distortion
View attachment 299607View attachment 299608
Very POWERFUL and CLEAN!
EHID
(If you're curious about EHID, here's a link to learn more.)
KEF Reference 2 meta Measurements and Review.
Hello, long time no see! I'm back with a center speaker from the KEF's Reference Series. I took pictures when I was measuring it, but the pictures provided by the manufacturer are cleaner, so I'm posting it here. Impedance Along with a smooth phase response, the linearity is...www.audiosciencereview.com
Again, this shows very clean THD measurement data.
95dB SPL@1m
View attachment 299610View attachment 299611
EHID
WHAT!!?
I'm honestly a little shocked by this one.
Prepare to be amazed.
Let me make it clear again.
I can't believe this..
95dB SPL....!
I opened the Klippel project file to double-check that the measurements were done correctly.
And soon, I had no choice but to accept the reality.
This is the insane Loudspeaker...
Multitone test
View attachment 299613View attachment 299614
Again, very clean.
Compared to the Reference 2 meta, it is slightly higher around 1 kHz.
80Hz~
Multitone test(with multiple output levels)
View attachment 299616View attachment 299617
I don't know what the hell is going on with this.
The output has increased to 96dB, but the percentage of MDs within 100-300Hz is still the same.
It hasn't increased at all.
Compression test
We do see some weakness between 100 and 200Hz, but overall it's a strong performer.
This speaker was specifically tested to 102dB SPL.
Grill test
My personal opinion.
Without a doubt, one of the best speakers out there.
Due to its size and weight class, comparisons to the Reference 2 meta are inevitable, and LF and Directivity are clear wins for the Reference 2 meta.
But if you're willing to compromise with your wallet, you'll be hard pressed to find a center speaker as good as this one.
Now, let's talk about something non-performance related.
I measured both R3 meta and R6 meta.
The owners of these speakers sent them to my studio via pre-order from a distributor.
However, I have returned and exchanged them three times: twice for the R3 meta and once for the R6 meta.
This was due to poor cosmetics.
It was a combination of bad paint and dented units.
There's no denying KEF's design capabilities and that the design is great.
However, having experienced everything from the LS50 to the Reference series, the failure rate of this meta-series is a far cry from what KEF has done in the past.
I don't know if there has been a change in process, but I fervently hope that this has improved.
