KEF R6 meta Measurements and Review
Nuyes
Reviewer
South Korea
Hi, again. This time, it's KEF's R6 meta.
Impedance
Frequency Response
It's pretty flat except for some of the HF above 10 kHz.
The bass extension is 70.7 Hz (-6 dB) with -14dB/oct slope.
Nearfield Measurements
Directivity
Overall, it's a very smooth and well-controlled Directivity.
Beamwidth
Narrowest around 5 kHz.
However, this is only a marginal difference that only appears when strictly compared to Reference 2 meta.
Polar plot
Due to the chunky mass of these speakers and the horizontally placed units, you can see that most of the sound is only radiating forward.
Beautiful attenuation all around, and uniformly controlled HF directivity.
Total Harmonic Distortion
Very POWERFUL and CLEAN!
EHID
(If you're curious about EHID, here's a link to learn more.)
Again, this shows very clean THD measurement data.
95dB SPL@1m
EHID
WHAT!!?
I'm honestly a little shocked by this one.
Prepare to be amazed.
Let me make it clear again.
I can't believe this..
95dB SPL....!
I opened the Klippel project file to double-check that the measurements were done correctly.
And soon, I had no choice but to accept the reality.
This is the insane Loudspeaker...
Multitone test
Again, very clean.
Compared to the Reference 2 meta, it is slightly higher around 1 kHz.
80Hz~
Multitone test(with multiple output levels)
I don't know what the hell is going on with this.
The output has increased to 96dB, but the percentage of MDs within 100-300Hz is still the same.
It hasn't increased at all.
What a beast the 6.5" woofer in the R6 meta is...
Compression test
We do see some weakness between 100 and 200Hz, but overall it's a strong performer.
This speaker was specifically tested to 102dB SPL.
Grill test
My personal opinion.
Without a doubt, one of the best speakers out there.
Due to its size and weight class, comparisons to the Reference 2 meta are inevitable, and LF and Directivity are clear wins for the Reference 2 meta.
But if you're willing to compromise with your wallet, you'll be hard pressed to find a center speaker as good as this one.
Now, let's talk about something non-performance related.
I measured both R3 meta and R6 meta.
The owners of these speakers sent them to my studio via pre-order from a distributor.
However, I have returned and exchanged them three times: twice for the R3 meta and once for the R6 meta.
This was due to poor cosmetics.
It was a combination of bad paint and dented units.
There's no denying KEF's design capabilities and that the design is great.
However, having experienced everything from the LS50 to the Reference series, the failure rate of this meta-series is a far cry from what KEF has done in the past.
I don't know if there has been a change in process, but I fervently hope that this has improved.
Gif comparison between Kef Reference 2 Meta and R6 Meta (data provided by @Nuyes):
EDIT: Added the rest of the graphs
It's late and I need to sleep now, so apologies if I missed a few graphs. Will double check tomorrow.
Fantastic and nice work! Thank you ;) and good night~!
Gif comparison between Kef R6 Meta and R3 Meta (data provided by @Nuyes):
Thanks for yet another awesome review!
This last part is really bad news... Packaging and shipping must improve immediately as this is an unacceptable defect rate.
Best center speaker tested so far I believe. Looking at KEF website it can be set up as LCR. Are there feet included in the box to allow you to sit it up vertically for use as LR channel?
Yes.
You can see how big these rubber feet are by watching this unboxing video (skip to 2min mark).
Yep, I can definitely see how this would be an excellent centre speaker, and centre speakers are normally rubbish!
Excellent. This makes the Reference 2 Meta a pretty tough sell at 3(!) times the cost. Going by the measurements alone, I don't see many differences that would be clearly audible beyond bass extension. For the cost savings, you could grab a pair a quality subs and still have a bunch of cash left over.
@Nuyes
Is a review KEF R2 meta coming anytime soon? I want to see if the directivity trade off is worth it.
Thank you so much for your work and effort!
@davidbosch @jackocleebrown
Hello gentlemen, If you could kindly entertain this small question I have over this design I would really appreciate it.
Is there a reason why you guys didn’t go for a higher crossover between the uni-q and the midwoofers? An amateur like me is under the impression that a crossover at 700Hz instead of 500Hz would yield a smoother horizontal directivity. Thank you!
Thanks for the review! I am happy that you are happy with the product's performance. The cosmetic issue is a shame... I should report about this.
Great measurements ! Thank you
Killer value but I still think having another R3 as centre speaker in vertical is a better deal
Kef continues to demonstrate its chops. I know $2k is not cheap, but if you want a high quality, good looking center for you home theater this is very hard to beat.
Hi, again.
Impedance
View attachment 299595View attachment 299596
Frequency Response
Directivity
View attachment 299599View attachment 299600View attachment 299601
Beamwidth
View attachment 299603View attachment 299604
Polar plot
View attachment 299607View attachment 299608
EHID
95dB SPL@1m
View attachment 299610View attachment 299611
EHID
WHAT!!?
95dB SPL....!
Multitone test
View attachment 299613View attachment 299614
Again, very clean.
80Hz~
View attachment 299616View attachment 299617
Compression test
Grill test
Holy schmoly guacamole! As an owner of the KEF R500 and Reference 3, these make me want to take out a second mortgage… were it not for the eventual divorce and homelessness… damn that is some amazing engineering and it goes without saying but thank you for your work and time!
