KEF R3 Speaker Review
BrokenEnglishGuy
I decided on a pair of 3000 Micro… mostly for watching videos. I switch with the iPhone app between Music and Movies. Also room correction with Roon.
I am pleased!
I always wonder if it's a good idea have something like the 3000 MICRO/KC62 with dual opposed drivers next to the speaker, if you put them
next to the cabinet of the speakers it's a bad idea?
Or if you want to have the subwoofer next to the speakers ( both things close ) is better a single driver sealed subwoofer? like a Rythmik f12?
Something like this is a good idea but I already have the R7 lol
Laserjock
Texas Coastal
Yeah, they’d be too high… :p
Steve Dallas
A Whole Other Country
What stands are people using with the R3s? It's hard to find something with a base plate that is big enough. It's frustrating that KEF doesn't make a speaker stand for the R3 like it does for the LS50.
Monolith stands are utilitarian, but very inert and stable once filled. (Mine are filled with baking soda.) They also come in different heights.
Other Monoprice stands look like they could be good, but I have not tried them.
Ace
I'm using Dynaudio Stand 20. Very solid and stable. Recommended.
As I've got wooden floors I simply reversed the feet so that the rubber end is down instead of the carpet spike.
fun
I put them on the Target HR60 stands that I have had for many years, and they works well and looks good. That say, with the price of those Target stands now (e.g. from Music Direct), I second Steve's suggestion regrading the Monolith stands, which I have the 28 inches version for my rear speakers. The Monolith are solid and great value, and should work for the R3.
syr1990
These look inticing. Are you using one of the bigger adapter plates?
Ace
No, the R3s sits with stability on the 15 x 21cm top plate. It has four rubber non-slip lugs that stop the speakers moving or damaging the base of the speaker.
testp
how's the R7 bass in a room?
Skyro
I second the Monoprice Monolith stands for the R3 if you don't want to spend an arm and a leg for speaker stands. R3 cabinet is already pretty inert as is but when I had some Triangle Br03's on them (which had very flimsy and resonant cabinets) the Monolith stands filled with play sand did really well to eliminate vibrations. I use blu tac to adhere them on the stands.
srslee
Would the Marantz NR1608 be enough to drive the R3s in a smaller bedroom? I would be adding a SB-1000 to the mix as well.
SuperDave
Philly
Although I'm unfamiliar with that AVR, I_do note in its' manual it has a setting specifically for 4 ohm speakers, which is of interest since the R3's are known to reach 3.2 ohm impedance. Marantz do not rate the unit's power output into 4 ohms, which made me look deeper. With that in mind, 50wpc/8 ohms in a small room with a decent sub should be fine. In fact, try the KEF standalone before you throw the money into a sub. Depending on your listening interests, you may find them sufficient on their own.
Steve Dallas
The 4 Ohm setting limits power. Do not use it. Leveraging a sub helps with low F current demand.
srslee
Good to hear. The money was already thrown into the sub long ago, haha. Just looking to take advantage of the R3 sale, and make use of what I have that's currently collecting dust!
Duly noted, thank you.
jmbgator
IsoAcoustics Aperta 200 Isolation Stands on top of Monolith THX 10 subs. :cool:View attachment 188897
How do the R3's sound on top of the subwoofer like this, and with the ISO stands? Generally, are there impacts to sound quality? I'm thinking of doing something similar with my setup and placing them on top of dual PB-3000s with the same ISO stands. Thoughts?
JRiggs
They sound fantastic. Could they sound better on stands and pulled further form the wall? Maybe, I don't know but I tend to doubt it. This is the best solution given the space I have to work with, and the system sounds pretty amazing. Really no different than a full range tower that incorporates subs.
My subs are Monolith THX 10's and they're built like tanks and do not vibrate. The ISO stands further reduce/eliminate any vibration. By have the R3 and subs positioned as they are, I am able to run a higher crossover between them, limiting strain on the R3, and there is no localization of the subs.
diddley
The Netherlands
I finally bought them for 1300 euro's at benderhifi.nl and they sound amazing!
The bass is perfect and the treble also.
I am a real happy camper now with the cx ste from cambridge and the r3's.
Thanks to eveybody contributing!
Laserjock
Texas Coastal
Congratulations, which finish/color did you get?
