Thank you for pointing that out and welcome!The top graph is 2db per division while the bottom is 1db per division.
FYI - Jeff Permanian is JTR Speakers.
While this is an objective forum there has been many questioning the subjective sound quality:
https://www.audiocircle.com/index.php?topic=137722.msg1465233#msg1465233
http://www.enjoythemusic.com/RMAF_2016/Holt/Digital_Amplifier_Company_JTR_Speakers.htm
... and not many ears survive that.Random subjective report: I drank a 12oz bottle of 5 year aged Dogfish Head 120 Minute IPA(19% ABV) tonight while listening to classical and classic rock music on these speakers at 105-115db at the mlp(4m) for 2 hours. No distortion, no compression. Not many loudspeakers can do that.
Also could you provide clarity in regard to the throat entry of the current design; does it have the curved transition profile necessary to provide geometric continuity?
That's funny because some of the guys using and modding JBL 4722s seem to put a flat spacer between the driver and the horn to improve the measured response.
Does that spacer eliminate the curved transition profile (do they chop it off) or merely extend the distance of driver to horn entry?
I can only speak for myself and I have been questioning objective sound quality (audible distortion) not subjective sound quality (personal preference).
Could you explain the reasoning behind going from a more advanced profile (JRT 3TX) to the current straight-sided horn.
The distortion is less than 0.30% below 6khz at 100db/1m. The 3TX is using an off the shelf horn. The horn on the 212RT provides 60 degree coverage over most of it range (some narrowing around 2khz). The angle of incidence is equal to the angle of reflection so horns with slow expansion near the throat will have issues from reflections and suffer from narrowing as frequency raises. The horn measurement article that you posted has a good diagram showing this. Please see attachment and look at #4 trace. Rectangle horns have been mentioned however they suffer from issues at the lowend of the horns range.
We have a contour machined into where the compression driver mounts to the horn. I've found it advantageous not to have slow expansion near the horn's throat.
Curious what amp/receiver are you using?? My room is a acoustic nightmare to say the least with a 18yr. old Yamaha ZR-1 amp and my JTRs sound awesome. I've had mine to 118db. without distortion. Cherry Monos someday.To be fair, I didn't start at those levels, but those are the levels I was reading towards the end. My ears were ringing for 20 minutes afterwards, so I know I did do some damage. Was my 30th birthday, though, and I had been aging that beer for 5 years. It sounded incredible.
These speakers have been tested by limiting only 1 watt to them with amazing results.Curious what amp/receiver are you using?? My room is a acoustic nightmare to say the least with a 18yr. old Yamaha ZR-1 amp and my JTRs sound awesome. I've had mine to 118db. without distortion. Cherry Monos someday.
