I should put in my 2 cents. I've got a pair of the 590's and suspected that I had a failed compression driver in one of my speakers. Luckily after showing support my THD graph, and a sound clip, Harman sent me 2x more compression drivers to rebuild the speaker myself. The distortion that I heard from the compression driver sounded like a square wave during the FR sweep. Though it wasn't just at 2 and 9KHz like this review shows. It was all through 1-5KHz.
I was able to replace the compression driver with a new one, and while I didn't do another THD measurement (only a few high SPL sweeps), it's been doing great in my home theater ever since.
So a few weeks go by after the repair, and curiosity struck. I decided to disassemble the 2414H compression driver, and I noticed that the voice coil was perfect, but with the solder joint for the voice coil was very likely rubbing on the channel in the magnet structure. I was able to spin the voice coil/throat end until I didn't feel rubbing, and reassemble it. I tested it out with a simple crossover outside of the speaker, and I was easily getting ~120dB without any audible distortion. Man, these compression drivers can put out SPL! I think they're rated for 130dB for the JBL EON's that use these 2414H's.
I feel that it's a bit of manufacturing and a bit of design flaw that causes this issue. The biggest hurdle to inspecting it yourself, is that getting to these compression drivers requires a few beers, a bit of cussing, and a heat gun to remove the waveguide and access the driver. I wouldn't recommend it.
If you do buy any of these JBL studio speakers, try running a FR sweep from 1K-20KHz, and listen for distortion. I'd say if you hear a square wave sound at ~105-115dB from 1-5KHz, you probably have a compression driver with part of the voice coil rubbing. I also noticed that it was a bit light on the ferrofluid, and it was pooling mostly to one side.
I'm surprised that the preference score is so low, but I run them with multEQ-X in a room with thick carpet and sound absorbent ceiling tiles.
In the end, despite the tweeter resonance, I'm happy as a clam due to the great bass output and sensitivity. Big sound > preference score? In my book, yes.
Nearfield measurement @2inches.
THD @ 2". faulty compression driver.
View attachment 306690 View attachment 306696View attachment 306697View attachment 306698
