computer-audiophile
Not true! There is also a cutout near the Horn entrance, the horn contour is disturbed.The general shape is still there, and there is only a small step
I'm honestly a little perplexed by what I'm seeing here, too. Maybe we need more independent measurements?Everyone is talking about about the 2Khz distortion,right?
What about that 10Khz nightmare?
We are all about tar and feathers if an amp has 103db SINAD over it's 106db specified SINAD for example and we forgive a speker that will iron everything to 40db SINAD (even worst @ 10KHZ) there?
That's odd...
I insist,there's must be something broken in there.
Some people are just overly dramatic lolThey are not bad at $1000. Just that they have more competition at higher prices. A dent in a $1000 used car is fine. It is not fine in a $50,000 car.
Well, yes, but the overall shape is still there.Not true! There is also a cutout near the Horn entrance, the horn contour is disturbed.
Everyone is talking about that the 2Khz distortion,right?
We are all about tar and feathers if an amp has 103db SINAD over it's 106db specified SINAD for example and we forgive a speaker that will iron everything to 40db SINAD (even worst @ 10KHZ) there?
That's odd...
Sorry but I have tried that kind of distortion with PKharmonic and is VERY much audible even lower than this.Higher order byproducts of 10KHz is probably not audible. Many of us dont even hear anything meaningful at 10KHz. The 1,4KHz distortion is more troublesome. However people are right when they say 2nd order distortion is not nearly as audible (and does not sound really bad) as one might suggest. Imo IMD is much more annoying.
Not a horn tweeter. As I understand it is a dome with a massive wave guide. Big difference. But maybe I’m wrong.that big horn
But then that dufus at gr research or whatever it’s called would not be able to sell you upgrades that cost the same as the speaker!I don’t care. It’s shit engineering and they should fix it.
I think maybe a different analogy might be more apt:A dent in a $1000 used car is fine. It is not fine in a $50,000 car.
Yah, well there is no way to know for sure if it makes a difference as it is impossible to isolate and to create a venue to compare the exact design with and without the harmonics added.I never complained about the audibility, I complained about the engineering, and mostly about the fact that this is present in so many JBL designs. It’s similar to the famous ESS IMD hump. Audibility is highly unlikely, yet we complain as soon as it shows up in measurements
I would not be surprised if it is of little consequence. The general shape is still there, and there is only a small step. Nevertheless, it would be interesting to see how much difference it really makes.
It is compression driver in a horn/waveguide, it is not a dome tweeter.Not a horn tweeter. As I understand it is a dome with a massive wave guide. Big difference. But maybe I’m wrong.
Yes, of course it is likley audible with test tones.Sorry but I have tried that kind of distortion with PKharmonic and is VERY much audible even lower than this.
I can even describe as the one 10Khz tone (which anyone can hear,you have to be 90 yo to not) seems like a two-tone signal as you increase distortion,it's "fater" and thicker.
But again,VERY much audible,you can try it with PKharmonic,etc.
Edit:link
I think the missing waveguide piece could create a 'whistling' or harmonic depending on the airflow being affected by the surfaces.Everyone is talking about that the 2Khz distortion,right?
That's odd...
Doesn’t look like it on the websiteAre these discontinued?
Well the tweeter in my 530's which is a step down from the tweeter used in the 590's can paly louder without any audible strain or measured strain that any other comparably priced set of speakers I have ever tested.Supposedly an advantage of compression drivers is their ability to play loud. But these measurements show considerable distortion at 96dB. Many dome tweeters have done better at that level. Granted, these are relatively inexpensive compression tweeters.....
There is a piece you put in to complete the waveguide if the grills are off. The speakers are packaged with it.(If the speaker cover is an integral part of the waveguide then it needs to be redone, although I have no idea if this is actually the case - but if it is then it should be redone, as speaker cover is an integral part of the speaker. Can understand why most people would review without speaker cover because normally they're supposed to be transparent or detrimental.)
Amir didn't use that extra piece then?There is a piece you put in to complete the waveguide if the grills are off. The speakers are packaged with it.
Maybe so but in review threads is not so much about audibility but engineering.Yes, of course it is likley audible with test tones.
With content I doubt it.
No.Amir didn't use that extra piece then?
Well, to be honest then, it should be remeasured with that in place, because they've obviously intended that to be there if you take the grills off! How much actual difference it makes would be genuinely interesting to see. I think it should be remeasured then.No.
I also use a bit of extra two sided tape at the bottom of the plastic as the piece fits a little loosly.
Yes, and the compression tweeter allows for high SPL playback at the expense of 2nd order HD.Maybe so but in review threads is not so much about audibility but engineering.
And people have trashed stuff way,WAY more inaudible than this to the point of shame.
Maybe this missing piece makes the difference but as is...
