Wut? REW shows you exactly what the output is from your PC.Now, is the output on my MBP HDMI with REW 0db? That I can’t say for sure.
I’d disagree on DIRAC only being important for more than 2 subs.NONE IMHO.
As Amir stated above, unless you have a need for the extra channels, the JBL won't by itself improve your sound quality at all.
I have a 4700H with all external amps and am very happy with it.
Possible that updating your 4800 to Dirac + Bass Management might bring something to the plate IF your running more than 2 subwoofer's but even then I doubt it. I've got 2 SVS SB2000 subs and Audyssey did a first rate job with them.
I'd enjoy what you’re running now, it's a top notch arrangement that will be extreme hard to improve on .
Oh wicked, I’ll run it back and check again. I’ve used it maybe 3 times, and know about 5% of what I’m doing in it lol.
So turns out it was a -12db tone from REW (as @Sancus posted). So instead of looking for 105db I should have been looking for 93, which would have been volume 78 for “reference level”.I have NC502 (Apollon) and NC252 (Nord) with my AV40. Using the RCA input those amps need only 1.6V for max output. My speaker a re couple of DB more sensitive and my room is a bit smaller but 80 volume is VERY loud and 90 unbearable for me.
Are you testing with a 0dB tone? Most THX tests use a -20dB or -30dB tone so you are aiming for 85dB for calibration.
Most films on disc peak at around -3 to -0.5 but reference level is always set on the assumption of 0. The volume setting on your Yamaha is quite high too but as you are finding out reference volume in most setups is whatever produces a 105dB peak in your room with your speakers and amps. 78 seems a touch high but within the realms of normal (Unlike 90).So turns out it was a -12db tone from REW (as @Sancus posted). So instead of looking for 105db I should have been looking for 93, which would have been volume 78 for “reference level”.
Tested with Dirac on vs off too, and Dirac is indeed eating up about 3.5db averaged (not including subwoofer where it’s higher). I’ll always be using Dirac however, so I won’t consider the “no room eq” measurements.
I guess then the only question is what level are most movies mixed at? Are most UHD discs gonna be 0db signal? Or is it widely dependent on the movie?
For the sake of testing I listened to a scene from 13 hours yesterday at 82 on the volume, and while it was quite loud, it was enjoyable. I’d routinely watch movies at -5 on my Yamaha AVR before which was post-YPAO, so I believe that was -5db in relation to the THX reference.
Any unit failing within a short a period of time should I would not invest in again throwing good money after bad.Can anyone speak to the reliability of these units? It's only a 1 year warranty right?
Curious if it's worth it to save $1700 and get a new one and hope any repairs are under $1700 or if I should just buy a new one.
I don't see SDP-55 in the pricelist anymore. Seems to be replaced by SDP-58. Processor prices fall like a rock when they are discontinued. The cost of the SDP-58 though has gone up to $6,900.Can anyone speak to the reliability of these units? It's only a 1 year warranty right?
Unless it's a dire need, wait until Q4, when Storm's Dirac ART exclusivity runs out and everyone else's ART strategy+abilities come out.Can anyone speak to the reliability of these units? It's only a 1 year warranty right?
That advice applies even if you don't plan to use ART. I suspect the resale value of AVR/Ps that can run ART will stay high, but anything with Dirac that cannot run ART will fall off a resale value cliff.
That's a fact! The last couple years have been hell for those of us with less than unlimited bank accounts.With inflation and price increases it's a bad time to wait for things,
The SDP-55, SDP-58 and Monolith HTP-1 all use the same DSP, if I'm not mistaken. The Monolith guys believe they can get ART running on it, and MDS advertises that same DSP card as capable of handling 24 channels, so presumably there should be some margin left. For the HTP-1 there might be the option to upgrade to a card with 2 of the same DSPs for only a few hundred US$, I have no idea if the JBL processors have an economical upgrade path.Is that worth potentially paying thousands more for though instead of $3600? With inflation and price increases it's a bad time to wait for things, though I would like ART to be promised by JBL... Just don't want to get caught after another price hike.
Unfortunate that everyone is going to have to work on their own implementations and everything besides Trinnov seems built with no overhead for additional processing in the future.
Dirac did say (during one of the interviews) - that an AVR capable of DLBC, should be capable of ART...The SDP-55, SDP-58 and Monolith HTP-1 all use the same DSP, if I'm not mistaken. The Monolith guys believe they can get ART running on it, and MDS advertises that same DSP card as capable of handling 24 channels, so presumably there should be some margin left. For the HTP-1 there might be the option to upgrade to a card with 2 of the same DSPs for only a few hundred US$, I have no idea if the JBL processors have an economical upgrade path.
That's the main issue. That is not much discount for an item that is discontinued.As an aside, $3600 sounds very high for an SDP-55 IMO.
Over here in the antipodes the MSRP is AU$13,000 and you are unlikely to find them used for anything less than AU$8000+That's the main issue. That is not much discount for an item that is discontinued.
How old is your SDP-55? I had weird issues like this back on original 1.1x firmware in 2020. 1.2x shortly after release resolved those issues and haven't had issues since.![]()
Anyone else having crazy issues like this using the JBL with a Nintendo Switch? When the switch turns off there are crazy noises that, when turned up, seem to be really bad for speakers and my ears.
Seems like the SDP 55 is broken with Dante still, as updates, different adaptors, clock leaders, cabled (HDMI and Ethernet) don't seem to fix this. Even if the Nintendo Switch sends out some little blips, is it seriously encoding this crap correctly and Dante is just accepting it as valid input instead of noise?
Plugging all the devices into the JBL fixed this issue somewhat, but there are other issues with ticks every 10 seconds after being 30 seconds into a song, or a white noise/scratchy screetch briefly when something starts playing. Crazy to think that studios use Dante, or perhaps it was crazy to trust a consumer device with this.
The Dolby SDP564 didn't have this issue with digital or analog output.
Analog output doesn't have this issue, but one of the primary reasons for getting the JBL SDP 55 is future board upgrades, Dante, and Dolby Volume. The board upgrades don't seem to fix things, Dante seems broken, and Dolby Volume settings were removed and replaced with presents.
Incredibly disappointed with the typical troubleshooting done by Harman, they should be asking for logs for intermittent issues, or a video, and they just ask what equipment I'm using and tell met to reset everything that kind of fixes some of the issues for maybe a day.
...And Audinate needs to test switches and give some suggestions for good ones to use that have PoE. Or just send moderately high bandwidth signals constantly even if it's silence just to prevent EEE or other things from interrupting.
Not sure, got it from a guy who had it sitting new in box in his basement for maybe a year.How old is your SDP-55? I had weird issues like this back on original 1.1x firmware in 2020. 1.2x shortly after release resolved those issues and haven't had issues since.
