JBL 708i Monitor Review (Passive: Part 1)
3ll3d00d
Yes I mentioned that variable Q was used long ago, e.g. https://www.ranecommercial.com/legacy/note101.html (you can see this was originally written in the early 80s). I have never personally encountered such filters in any remotely modern DSP device either. It's not that obvious why storm even mention them, seems basically irrelevant to their point (which is about adjusting high frequency filters that come from other modern dsp implementations).
jdubs
I understand JBL don't actually come out and state this up front, but 708i is an DSP-equalized and limited, passive-crossover speaker. It has a passive two-way crossover inside that can be used either with a single amplifier plus DSP or two amplifiers plus DSP. It can be bi-amplified, but the only difference is the DSP EQ is now split between LF and HF, the amps are full-range and crossovers are all passive. That's how Amir is able to operate the speaker with a single amplifier, and he mentions the passive crossover in the review. Careful reading of JBLs literature confirms what I am writing to you.
In summary of what the speaker actually is: It's designed to use one or two amplifiers per customer's choice. It has passive crossovers only. It uses DSP for shelving and notch filtering only.
So that you don't misinterpret my words, here is a picture of the DSP filters directly from London Architect EQ files for HF and LF:
I think this doesn't account for the input filters or the compressor.
-Jim
pierre
Switzerland
Interesting pdf, I didn't know about differences between constant-Q and non constant-Q. I use parametric filters a lot for EQ'ing headphones & speakers using REW software to model the effects of the parametric filters on the measured frequency responses of the headphones & speakers, and that uses constant-Q from my understanding of your pdf. In fact, every piece of EQ software I've ever used stipulates Q in this same way - as in the filters are universal & interchangeable (give the same results) between all the different EQ software I've used. I'll list the different EQ software and "systems" I've used: REW / EqualiserAPO (& Peace) / Neutron Player / AutoEQ (github) / miniDSP - it's also the same definition of filters used by everyone in the headphone EQ arena - Oratory1990 / Crinacle / Resolve / Innerfidelity / jaakkopasanen(@AutoEQ). I've never come across any implementation that uses non-constant Q. (I think you made a mistake or typo in your first or second sentence, because you're referring to constant Q in both so there's a logical mismatch happening there regardless.) And I think you must be wrong in saying miniDSP / Roon / Pierre don't use constant Q filters.
EDIT: unless there's a 3rd type of Q that isn't described as constant-Q or non-constant-Q. Either way all the parametric filters I've ever used behave like the following pic in your pdf you linked (note within each graph below the Q value is the same between each of the different graphed lines (within a graph), and the only difference is the amount of Gain, which is where the misunderstanding could be happening with those who have glossed over the pdf):
and they've never behaved like the following which is non-constant Q (note that the pdf is saying the Q value of the following two graphed filters are the same, only the Gain is different):
EDIT #2: I noticed @pierre put a "Like" on your post, I think he didn't read the pdf in-depth as he's an experienced guy using EQ, so I think he just made an assumption that "constant-Q" meant a Q of 1.41 rather than a person being able to stipulate their Q-value, but that's not what the pdf is referring to in terms of what is meant by "constant-Q".
EDIT#3: There might be a third type called "proportional Q" (after I googled the topic), which might be what most EQ software uses, but that is certainly not the same as the "Figure 2" graph above, and instead looks more like the "Figure 3" graph above (when I model it in REW) which is what Storm Audio is saying is Constant-Q. I'm not sure that Storm Audio have covered off all the different types of Q. @oratory1990 , could you clear this up for us, any misunderstandings that are happening in my post & the one I replied to? (Meanwhile & also @GaryH, I know you like understanding & using EQ, have you come across any of these definitions? I was surprised I didn't know about them.)
I did read the paper. That's confusing.
So we have (at least):
- constant Q like in graphical EQ (with Q varying between equalizers either 1/3 octave or 2/3 octave bandwidth see below)
- constant Q like in Storm paper Q(storm) = Q * K with K = 2pi f_c/fs / sin(2pi fc / fs)
- proportional Q (what most things used nowaday)
- (band)width (and you can compute a corresponding proportional Q = sqrt( 2^W)/(2^W-1) ; that's the width you see in the EQ above from JBL)
there is still a slope parameter that I don't know what to do with. I am also not sure why it is easier to optimise with the storm Q that with a parametric one.
Robbo99999
Well, it certainly is confusing, and the terminology doesn't help. The Storm pdf refer to Constant & Non-Constant Q, and that's nothing to do with whether the Q-value has to remain the same or not within your parametric filter (you can still choose any Q value you want for your filter), they're in fact saying the definition of Q is different when referring to Constant vs Non-Constant Q. The main takeaway for me being that Non-Constant Q means that for two filters that have the same Q value then the filter that has a larger Gain (negative or positive) will effect less frequency range either side of the central point, as per the following graph they used:
Now that kind of definition of Q I have never seen before (above), which makes me think their definition of Constant Q is the common version that we see, as per the following graph that shows a number of filters all with the same Q value but different Gain:
And the above graph is the visual behaviour I'm used to seeing when it comes to keeping the Q-value the same and increasing the Gain - so this leads me to believe most EQ implementations are of the Constant Q variety. Note this has nothing to do with the idea that the Q value that you input into the filter has to remain the same for each filter you use (it doesn't have to remain the same), as explained in the bolded part at the beginning of this post.
minor possibly unprobable EDIT: or the Storm pdf is a load of baloney and they don't even understand it and are confusing some simple principles which is leading us down the garden path.
EDIT #2: for what it's worth, I don't think this matters too much, as all the implementations of EQ that I've seen through software programs as well as devices like miniDSP all use the same type of the EQ that is translateable from one to another: ie for example a 30Hz, +6dB, Q1 filter will look the same between all the software & devices I've ever used.
Reactions: MAB
jhaider
Has anyone converted this data for use with REW?
Robbo99999
There's the usual zip file that Amir attaches to all his speaker measurements that contains text files that contain the spinorama data. I think you can just import that into REW, then you'd be able to devise some of your own EQ filters and then use whatever "EQ applying" program or solution you want (EqualiserAPO, parametric EQ in music players, miniDSP, etc).
EDIT: you might need to remove some of the columns from text file. Importing a measurement into REW when I've done it is just two columns, frequency & the SPL(dB). I did this in the past by copying & pasting into a spreadsheet, then deleting the unwanted columns, then copy & pasting the remining two columns into a notepad text file editor (word processing program) and then saving it as a new text file - it now has just the two columns you need to import as a measurement into REW. There might be more time efficient ways of cracking the same egg.
Rahan
France => Canada
Not necessarily. “Studio monitors” (which this is) and “hifi” speakers often use the same parts. One of the comparisons posted is, like 708, marketed as a studio monitor. It uses a Seas woofer, like one may find in a “hifi” speaker. Amphion is another that uses the same types of drivers (also Seas in that case.) Genelec’s previous flagship subwoofer (the 4x12 ported monster Keith Yates measured for his “way down deep” series) used Peerless XLS woofers just like any number of commercial and DIY home subs.
For another example, as previously discussed Sound und Recording found Neumann’s brand new KH150 to have bass capabilities equivalent to the the smaller speaker in this series, 705, despite the Neumann using a 6.5” class woofer and 705 using a 5” midwoofer in much smaller cabinet.
Point is the drive units in 7-series are stars. I haven’t looked at all of Erin’s tests, but I suspect you won’t find another speaker with an 8” woofer that’s close - and maybe not one with a 10 or even 12 either. It’s too bad we don’t have comparable compression data between, e.g. 708 and Neumann KH420 or Genelec 8351. Erin hasn’t measured the other two, S-u-R hasn’t measured 708, and Amir doesn’t do compression testing.
How did you find that 708s driver is Seas ?.
GXAlan
Waxx
Wodecq, Hainaut, Belgium
JBL certainly does not use Seas drivers, their core bussiness since start is drivers, as James B Lansing, the founder is one of the pioneers of loudspeaker and driver design, and one of the engineers behind the invention of the modern speaker systems like we know it today as part of the joint venture arround MGM (where his company, Lansing Manufacturing was part of) to launch the Shearer Horn in 1937. Lansing Manufacturing became later Altec Lansing, and after the sale of that company. Lansing started JBL.
JBL always makes their own drivers inhouse, and worked as OEM driver builder for other companies just like Seas did. And that did not change during the different periods of ownership by bigger companies, up to today. It's a big and essential part of the JBL identity.
GXAlan
Well, that’s not entirely true. One of the big brouhaha’s was that they revised the in-house drivers of the DD67000 to Radian ones. That is, the 877Be is likely Radian/modified Radian.
That said I think it is because JBL likely dropped all beryllium diaphragms for their Professional products as well.
This may be related to evolving technology where you don’t need beryllium to achieve good results and you also have increasing concern about the risks for workers who work with the material
https://www.federalregister.gov/doc...g-the-beryllium-standard-for-general-industry
Mr. Widget
SF Bay Area
Mostly true... here is a great reference on the history of Lansing Manufacturing, Altec, and JBL.
Regarding always building their own drivers, at times JBL/Harman has bought up other companies to use their products. For example they owned and used Audax tweeters for a time and as @GXAlan points out they currently have an arrangement with Radian.
617
Somerville, MA
They used SB Acoustics for Revel for a period as well. And then copied them? I don't know the full story.
I would assume all the JBL Pro and Cinema drivers are designed by them though. Surprised they're working with Radian.
GXAlan
Revel as a brand has more consistently used third party. The original Revel Ultima used ScanSpeak tweeters, although they were custom for Revel.
I think the Radian driver in the latest DD67000 is the first true third party product but as far as I can tell, all of the new products coming out from the Synthesis line are still made in JBL Mexico products.
Waxx
Revel is not JBL, they are both owned by the same mother company, but they are very different brands with very different history and tech.
That would be the first that i know about. I don't follow JBL that close now, but never heared about them using other drivers, nor recognised other drivers in their systems. But it's certainly not something that they do a lot like a lot of speaker brands do. And they surely know how to make good drivers, theirs are seen as among the best arround in any style ever. They don't need OEM tech, maybe it's just economics that made them do it.
Mr. Widget
SF Bay Area
Even this Radian driver is using a custom JBL Be diaphragm made by Marterion for JBL with JBL's proprietary diamond shaped surround.
Early on Revel was based out of some of Harman's facilities back east, but even then the 15" woofer used in the original Revel Ultima Sub-15 was based on a JBL pro audio frame and motor with a unique cone and surround. It was prototyped and developed right along side the other Harman brands like JBL Consumer, JBL Professional, and Infinity.
Today JBL and Revel use the same R&D department at Harman's facility in Northridge California where they share the anechoic chambers, listening rooms, and offices.
jhaider
I didn’t because it doesn’t. The antecedent for “it” in your quoted text is “One of the comparisons posted above…marketed as a studio monitor”
That said, I would not be surprised if its compression driver shared considerable DNA with the baby BMS. Regardless, it’s not the same driver. The phase plug is a proprietary design.
Rahan
France => Canada
Well, it's clear now. Thanks. Personally I think it's a good thing to work with other manufacturers like radian for jbl. It is often a win/win situation. It's a costly operation to build from starch a new driver. Most time they use it in many different speakers. The compression driver of the 7 series (2409h) is used in some synthesis line (SLC-5 )and others pro cinema line (c221 etc..) But I don't remember seeing 728G used except on the 708.
GXAlan
That’s good insight. Then it is still arguably a JBL transducer.
That’s cool.
I don’t see anything else using the 728G but it is probably a ferrite version of the 8” differential drive woofers used in the VRX. The L100, 4319, 4312E all used one-off woofers that weren’t found elsewhere.
Rahan
France => Canada
Do you think it' s realy important to start with jbl dsp preset even on single wire configuration and then do the room correction. Or should I start from scratch and make my target curve with REW then make all filtres from that.?
jdubs
That's what I did for mine (start with the JBL presets and then do room correction) and it turned out great.
-Jim
