Absolutely. It's a matter of taste. The trick is to make it work in practice. You can have both. Connect the subwoofer when you want some electro, disco party in the room. Although it will be a bit to do if it is worth doing? You can always, if you have EQ / tone controls turn on the bass when you then feel like it.Personally, but this is a very personal thing, I am averse to pumping deeper bass into small rooms. This excites room modes at much higher frequencies than in larger rooms, and room modes at these higher frequencies are more unpleasant. At the same time, equalizing at higher frequencies only works for narrower and narrower listening positions, the higher you go. If the choice is between boomy bass and less bass, I prefer the latter.
Also, I do not know what kind of music mushjoon is listening to.
Edit:
Mushjoon: ...since I won't be blasting Entombed at 2AM unlike some degenerates who sometimes play loud hiphop music at 3AM..
Aha, sorry. I missed it. Forget my suggestions.
Neighbors I just say...
Although you can have a lot of fun with your neighbors.
