If Bits are Bits
ahofer
New York City
It never stops
Cbdb2
Vancouver
I'm calling BS. The author needs to learn about digital modulation. There are many ways to encode digital not a "almost universal " amplitude shift keying. Actually ASK is one of the least used. If digital transmission is such a problem why does my bank account never automatically change?
"The most fundamental digital modulation techniques are based on keying:
So how does a cable destroy a phase change, or a freq. change?
KSTR
Berlin, Germany
I think all of the confusion comes from mixing up the abstract concept of a digital transmission channel where "bits are bits" as long as there are no symbol errors (after error correction via redundancy, if applicable) and the potential side-effects of the actual transport mechanism on the final analog output of the DAC converting bit-perfect input streams which is purely an implementation issue. Jitter would be one well-known ill-effect but there are several others like RF demodulation, GND or reference voltage disturbance etc.
This means, quoting Mr. Hansen "all of the problems of digital are analog [signal integrity] problems", is spot on.
Cbdb2
Vancouver
Texas Instruments first home computer (1979) https://en.wikipedia.org/wiki/TI-99/4A delivered some of there games on audio cassettes, and you could back stuff up on them. My friend used a cheap dictation cassette deck and never had a problem. And all the analog problems from a cheap cassette tape recorder meant nothing to the bits. They all returned intact.
C3dr!c
Hello,
I experienced with my Cary Audio CD-306 Pro that at 44.1 KHz, 16 bit, CDs sound much denser and thicker than files (wave 44.1KHz, 16bits).
Same experience with a simple DVD player, same result! The sound of CDs is denser.
I pointed this out to my specialist hi-fi dealer,
he told me that he had already noticed this phenomenon and had no explanation.
Whoever has a doubt must experience it.
Reguards
GXAlan
Hello,
Reguards
You can record the output to analyse. It’s a respectably good DAC, but I can imagine different upsampling being used or HDCD decoding or differences in the digital filter playing a role too. Could even be as simple as different volume levels.
https://www.stereophile.com/content...ofessional-version-sacdcd-player-measurements
antcollinet
UK/Cheshire
That was my first thought too.
Seems odd that a file would play at a different level compared with a CD on the same device - but Ive heard of it happening before. I guess if it has separate chipsets that handle CD audio compared with file audio that could happen.
Berwhale
As physical media, CDs are certainly denser than wav files which are encoded as vibrations in the luminiferous aether and therefore weigh very little :)
Galliardist
Sydney. NSW, Australia
Hello,
Reguards
Whoever has a doubt probably won't experience it. I certainly don't. I just checked, CDs against EAC rips of the same CDs, so that I could definitely say that. (USB drive, before you ask).
Maybe my overpriced player isn't resolving enough, or something. And I bet your seller of CD players checked that you thought "denser" equals "better" before agreeing?
Welcome to ASR, the land where we have a doubt :) ... and there is no intrinsic reason for two identical bitstreams to sound different.
Our new friend has experienced this on two players of different standards in two systems, though. I guess the same differences could be in play, and would have to point to the music in use, or the listener, as the most likely causes of this.
@C3dr!c, if you haven't read much on this forum, we tend to "blame" listeners a lot here, including ourselves, and you will get the "do a blind test" response soon enough. It's OK. Your brain is supposed to interpret what the ears hear, but also other senses and memory, to tell you what you are "actually" hearing, This works great in the real world and gives you a coherent view of the world to act on. Not so good for evaluating hifi though.
On the other hand, it's always nice to know when there is a chance of a real world difference. So, can we have more details? What about your system with the DVD player? And where do the files come from?
Chrispy
PNW
Hello,
Reguards
Just what does denser and thicker sound even mean, tho? I think your hifi dealer likely just has no clue, as most of them don't, and just wanted to not disagree with you.
MAB
Portland, OR, USA
Hello,
Reguards
This is how I used to sell cables and tiptoes and other things that made no difference in the sound.
Welcome to ASR.
A veil or two may be lifted.
Sorry you spent so much money on a CD player already. But it wont play the same digital file any differently than the same data rendered via a different path.
The source (i.e. the recording) matters.
Your speakers matter.
Your room matters.
The computational device and the cable or I/O that the device gets the data from doesn't matter one iota. And thanks to that since many more mission-critical tasks require data to be rendered properly irrespective of the machine.
Cbdb2
Vancouver
Hello,
Reguards
Where did the wave files come from? Wave files have more error correction than CDs and are a better format and the standard file format for studios. I've never heard a difference from ripped CDs to wave.
ahofer
New York City
Welcome to ASR.
Your room matters.
Yes. When I was on the floor the first rule was validate the customer’s observations, no matter how stupid. Customers say all kinds of weird stuff. Like improv comedy, you go with it, trying to connect it to something you sell.
Hayabusa
Abu Dhabi
We hear from folks that bits are bits. Why does a CD redbook player sound better than a Streamer at 44.1/16, or even DSD.
I dont hear it
Hayabusa
Abu Dhabi
No, they don't. WAV files have no error correction at all.
The wav files enjoy the error correction of the medium they are stored on or streaming protocol they are streamed with. But if you really want to be right: no error correction in the files themself
