Making the contact areas gas tight. There is quite a science to the behaviour of metal to metal surfaces, and when contaminants can intrude things get complicated, fast. Google "Ragnar Holm electrical contacts" to see what's out there.
Signal won't be attenuated with imperfect contacts, but they form an area of non-linear resistance very quickly when atmospheric gases are present. Yes, at very low resistances, but IME just enough to cause audible effects. Solution: clean the surfaces and immediately form a solid barrier which permeates the contact area, and excludes all contaminants - solder is ideal. The only other method that I found works are the silver greases and paints that are made for this job - used correctly, they are as effective as solder.
It's easy for anyone to see if this may be effective for their system, and hearing. Run the system for a bit, until everything is stabilised; then in a single exercise go through the whole system and "refresh" every contact, by unplugging and reconnecting, etc, from the source to the speakers; and then immediately listen again. If this appears to make absolutely no difference, then it's most likely not worth concerning yourself about this any more.
Nickel plating is durable, non- corrosive and has been an industry standard 'forever'. Gold is unnecessary, silver corrodes with sulphur in the air. Contact pressure should be firm.
If you have problems with connectors there is a problem with their mechanical fitness for purpose or the wrong ones(material compatibility) are utilised. Sound connections can be made with decent plugs and sockets - this is basic telephony engineering.
If in doubt, use what the commercial audio sound installations use. They get hard use and have to keep on performing.
Soldering can have even more issues in the work of the unknowledgeable and unskilful in the craft.
P.S. Is it really gold? http://www.sxwjdd.com/html_news/Imitation-gold-plating-process-11.html
