Received mine from Rouge Audio yesterday.
I requested a custom build with:
- WBT Binding posts
- Neutik XLR connectors
- Only one Power supply (My horn speakers are 16Ohm so I need the voltage but with less power)
- An additional trigger input that works with 5V
- White frontplane with custom engraving
- No power switch at the front
The amp arrived very well packaged and worked flawlessly right out of the box. I'm going to be running it for a few days now to burn it in before critical listening.
The housing is made of sheet steel. Technically great but missing some glamor and the feeling of high-end quality.
The trigger input is galvanically isolated from the amp to avoid ground loops
I was wondering about the funny non-standard connector they used for the trigger. It's a connector you'd typically see on power adapters rather than the standard 3.5mm plug. The trigger board completely removes power instead of using the SMPS1200's standby functionality. Maybe they offer that too, but I didn't ask. In the beginning the trigger was only designed for 12V but I need it to work with 5V as well. Francesco was kind enough to switch it to 5V. I really appreciate that he didn't ask for an extra fee for this change!
Like to share some photos here.
