I think those switches look classy.Not unless the rest of the package changes. Meaning integrated PSU and replacing those cheap stick-switches on the front with some nicely machined buttons.
The v3 mono will cost no more than 0.5W in stand mode.I am curious about the standby power consumption. Has It been measured jet bij @amirm?
Within the EU there are regulations telling manufacturers to minimize power consumption of the devices they are producing.
A wide range of equipment – audio and video equipment, microwave ovens and electric toys – can have standby and off modes.
since 2009 these devices are required to switch to a low-power mode (such as standby) after a reasonable amount of time
since 2013, they must not consume more than 0.5 Watts in standby or in off mode, or 1 Watt if they are on standby while displaying their status or information
EU Ecodesign requirements are mandatory for all manufacturers and suppliers wishing to sell products consuming electric power in standby and off mode in the EU.
Standby, networked standby and Off mode
Off mode, standby and networked standby mode. Energy efficiency of products.energy-efficient-products.ec.europa.eu
Does Fosi meet these requirements?
Our team has confirmed through testing that when two V3 Monos are connected to a single 48V/10A power supply via the Y splitter cable, the output power of each is the same as a single V3 Mono connected to a 48V/5A power supply.Hi, you write that it is possible to connect 2 amps to 1 48v power block. Is this degrades the power of the amps? To get full power should I use 2?
What about noise over a period of time (until the oscillators drift one cycle)? Can you share some measurements?Our team has confirmed through testing that when two V3 Monos are connected to a single 48V/10A power supply via the Y splitter cable, the output power of each is the same as a single V3 Mono connected to a 48V/5A power supply.![]()
So the upcoming preamp (ZD3) will be same form factor/width as ZA3 and not V3 variants?
Sorry, we need to make a revision that the input impedance for RCA is 25kΩ, and for XLR, it is 5kΩ.47kOhm for the RCA input.
Sorry, we need to make a revision that the input impedance for RCA is 25kΩ, and for XLR, it is 5kΩ.![]()
They have tested and it makes no difference. Plus you can purchase their or some other power supplies on Amazon or their website to go that route. Let's not forget the cost of these things and the fact this is using high quality components that stuff costing far more don't use.The only SLIGHT problem I might have in buying a couple of these is this. On their webpage for this new unit there is the following: "With a power supply splitter cable, a single PSU can supply power to two amps, saving space and maintaining tidiness, offering you more flexible combination solutions.", which suggests you could potentially buy two of the amps, but just one power supply unit. I asked Fosi directly about this, and - to their credit - got a reply reasonably quickly: "It will launch on Kickstarter on April 20th, there isn't the option to purchase two units but with just one power supply". It seems just a fraction disingenuous, therefore, to tout the benefits of a single power supply for two amps but then say that option is not available.
Unless you have an AM radio in the same cabinet it’s irrelevant. I have 4 modules in a diy amp without using the clock slaving and it’s fine.The power supply sharing is something interesting to me. Actually, various TPA3255 can be operated in master/slave mode so that they delay the switching between each other, apparently to "minimize noise coupling between audio channels through the power supply." and "Inter-channel delay is needed to optimize audio performance and to get better operating conditions for the power supply" according to the datasheet (below).
Given the fact that most probably two fosi sharing PSU with one of these Y cables are in fact directly connected in between, but not in master/slave mode, i would be curious to understand what this means for the performance of the amps and the power supply.
I don't see how this comment is relevant to the issue raised. Yes, they say the 10A power supply performs the same powering two amps as the 'normal' 5A one does with a single amp, but the point I raised is the fact that they have no plans to offer buyers the opportunity to buy 2 amps plus the single 10A power supply. The availability or otherwise of 3rd-party power suplies is irrelevant.They have tested and it makes no difference. Plus you can purchase their or some other power supplies on Amazon or their website to go that route. Let's not forget the cost of these things and the fact this is using high quality components that stuff costing far more don't use.
That… doesn’t make much sense? The power supplies are DCWhat about noise over a period of time (until the oscillators drift one cycle)? Can you share some measurements?
Sorry for the inconvenience. We'll provide the option of one 48V/10A PSU+Two V3 Monos on Kickstarter.The only SLIGHT problem I might have in buying a couple of these is this. On their webpage for this new unit there is the following: "With a power supply splitter cable, a single PSU can supply power to two amps, saving space and maintaining tidiness, offering you more flexible combination solutions.", which suggests you could potentially buy two of the amps, but just one power supply unit. I asked Fosi directly about this, and - to their credit - got a reply reasonably quickly: "It will launch on Kickstarter on April 20th, there isn't the option to purchase two units but with just one power supply". It seems just a fraction disingenuous, therefore, to tout the benefits of a single power supply for two amps but then say that option is not available.
Can't say fairer than that. This is why folks like us are interested in Fosi's products. The company is responsive to user feedback, and flexible enough to adjust accordingly. That is the way you build a loyal customer base! Kudos to you!Sorry for the inconvenience. We'll provide the option of one 48V/10A+ Two V3 Monos on Kickstarter.
See the extract from TIs datasheet you quoted a few posts aboveThat… doesn’t make much sense? The power supplies are DC
They offer the power supplies, but individual ones are desperate items. Don't forget that the majority of their customer base won't even think about power supplies and just use the one provided. I get what you are saying, but it's a simple fix by purchasing the required power supplies you desire.I don't see how this comment is relevant to the issue raised. Yes, they say the 10A power supply performs the same powering two amps as the 'normal' 5A one does with a single amp, but the point I raised is the fact that they have no plans to offer buyers the opportunity to buy 2 amps plus the single 10A power supply. The availability or otherwise of 3rd-party power suplies is irrelevant.
See their most recent post. As a direct result of this forum they are going to make the option of buying 2 amps and just the single 10A supply available. Problem solved!They offer the power supplies, but individual ones are desperate items. Don't forget that the majority of their customer base won't even think about power supplies and just use the one provided. I get what you are saying, but it's a simple fix by purchasing the required power supplies you desire.
Sharing power supplies is irrelevant to that though. The linkage is between the clocks in the amp chips. In principle clock drift between chips can create lower frequency “beating” signals that cause interference with low frequency radios. It’s got nothing to do with noise and even less to do with the power supplies!See the extract from TIs datasheet you quoted a few posts above
