This ‘module ‘ contains a list
but analogue in is not amongst the options
for some reason (can`t) really explain why I always found the Minidsp producst a bit flimsy.. JustJones : If analogue and digital DSP or EQ is wanted why not look at Trinnov Nova or RME adi 2-4. For some strange reason i see Eversolo a bit like Oppo was a few years ago, not super well known but construction appears to be sturdy. For me the A8 seems interesting bcs of the arc HDMI and DSP other than that I would consider the A6Minidsp SHD routes analog through DSP.
The Trinnov Nova with their measurement mic is about $4200. The Minidsp was closer to the price of the A8 and did analog in through their matrix which @Dr.Deadwax was looking for. It also has Dirac if that's something one's interested in. Perhaps in a professional setting Minidsp wouldn't be rugged enough but for home use they're fine.for some reason (can`t) really explain why I always found the Minidsp producst a bit flimsy.. JustJones : If analogue and digital DSP or EQ is wanted why not look at Trinnov Nova or RME adi 2-4. For some strange reason i see Eversolo a bit like Oppo was a few years ago, not super well known but construction appears to be sturdy. For me the A8 seems interesting bcs of the arc HDMI and DSP other than that I would consider the A6
The A6 doesn't have ARC in but they said they're implementing DSP in them with a firmware upgrade.me the A8 seems interesting bcs of the arc HDMI and DSP other than that I would consider the A6
For what you have in mind, I would take a NAD M10, for example, and if phono MM is desired and you don't have a phono pre amp, I would add a Bluesound HUB (max. 4x HUB on single network (8 simultaneous streams)).Is it possible to use the DSP for the analog inputs? Does this mean that the signal is digitized beforehand and if so, at what sampling rate?
Is it possible to convert the DSD signal into PCM for example in 176.4 khz / 24 bit and then use the DSP like many home theater receivers do.
Does having an analogue preamp instead if a digital one improve the sound quality if used with active speakers that first convert the analogue signal into digital and then back into analogue after the crossover?
If so, that would be the only reason why I'd be more interested in the A8 vs an A6 Master Edition.
MiniDSP SHD is a streaming, DRC, analogue input, pre-amp.A one box streaming/DRC/ preamp is not available at the moment. if your budget extends to a Linn Sekekt, then you could go for an NAD M66 or opt for a 2 box solution if you cannot wait.
The M66 are you talking about? Well currently the product and manual are not released, but given the M33 has three selectable ADC rates for it's analogue input (48,96,192khz) - I would expect the M66 to offer the same. I have read that it runs Dirac internally at 192khz so would make sense.But NAD digitizes the analog inputs in 16/44.1 khz
why do you say this? It is not correct.But NAD digitizes the analog inputs in 16/44.1 khz
