Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.3%
    Votes: 25 4.8%
    Votes: 145 27.8%
    Votes: 345 66.1%
Cepi
France
Hi Eversolo community, little question ... do you manage to make "squeezebox" work well on the A6 ? do you manage to find your SSD files or files ?
Stefti
Hi Team
I`ve tried to update (via USB)the A6 from 1.1.50 to 1.60 but It got stuck during the boot-up, so I`ve factory reset the unit and it prompted me to the new 1.1.80 which I did
since then I`ve lost the EQ setting on the main screen and the apps now are back to my initial (last August) settings
Do I need to update the Android version as well and how? I do that? (Android app v.1.12.35)
So the firmware is at 1.80 but the software is the old one?
Any Clue?
Or did I just brick the unit ...
Stefti
This is a discussion from the zidoo forums...
Me:
Could I have accidentally updated the A6 with the A8 firmware?
Who can know this better than you?
The machine eats everything you serve - not good and often complained about. But nothing changed. So this might be the case.
Me:
Yes ..because the updater did
I`ve updated the firmware using the 1.06
but soon after reboot, there was an update this time V1.80 so I did...nothing more
also, it doesn`t even see the added files from the CD burner
Yes I did it myself because it made me do it
now I`m left with a broken $1k streamer
Doesn't look good
Me:
I`ve burned CD images as usual (twice FLAC and WAV) one on the SSD and one in the local storage scanned both drives =0 result
Did the reset twice one`s hard and a second after the re-install of the A6 firmware
Never had any problems before
I wish I had an image(ISO) or backup
If anyone has it please let me use it
Because now it`s not longer a $1K streamer but a broken (cheap) phone
Please let me know If anyone can help
Thanks
Stefti
I`ve managed after hard and soft resets to re-install the 1.1.60 (from the USB)afterward it updates itself to the 1.80 again
scanned and found all my residual files
So far so good for now ...
GordonParet
Kelowna, BC
Me:
Me:
Doesn't look good
Thanks
You are trying to install an old firmware. The current firmware version for the A6 is 1.2.50.
Salt
DE
Posted this question in Zidoo forum?
Stefti
Yes, I did post it in the Zidoo forums and sent an inquiry to Eversolo Tech which was kind enough to respond. I explained every step I made until the unit (dmpA6) was fully functional and upgraded to v.1.2.50
If you want I`ll explain the steps I`ve taken
I`ve assumed the unit software was compromised and hoped for a replacement or some kind of software tool to reset the unit
Sorry for the late reply, and I appreciate your inquiry
The Moog
@mirror88 Any news on the next firmware update, even a beta release? I have seen no news since the beginning of March, when it was suggested that an update was a month away.
Stuj
Sydney AUS
It’s been quiet for quite a while, and its coming up to 1 year since the A6 product announcement, could there be a new product on the horizon that is drawing their attention away from this I ponder….
The Moog
In terms of software development resource (rather than hardware design and development) I can't think of an Eversolo hi-fi product that would require more effort than a streamer, with all of the standards and third-party services that it has to play nicely with. I would also assume that this development effort would continue to be leveraged; the A6 and A8 share the same basic software with feature differences, and I would expect this to be true for any new similar products.
Purité Audio
Industry Insider
Barrowmaster
London
Given their decision to launch a gold badge version of the A-6 a ‘special edition’ A-8 wouldn’t surprise me.
With ’femtos’ .
The Moog
With ’femtos’ .
I have no problem with that; there are many things that influence people purchasing decisions beyond a products performance and I am fine with the company catering to that. What I was suggesting is that this should not impact the development of their streamer software.
Akary
Doesn't the optical port accept Dolby Digital signals, not even 2.0? I tried from the TV but it just gave me a buzz or put PCM and it works
mirror88
There will be a new firmware in May. Except with some new streaming services, I'm sure it will bring Gapless playback of CDs
Monkey3017
Also M3U playlist support? Would be really important for many.
The implemention could be done quickly with this shortcut: Take all files in the M3U file and push into the playing cue.
The MusicRemote.exe already creates M3U files for other devices. It would be great if those could be also played on the A6.
jiji
Is there a gapless playback on the internal player, when playing FLAC files from the SSD?
I saw some information about gapless playback in Ever solo Engine, but gapless playback doesn't work for me even if I activate Eversolo audio Engine.
Am I doing anything wrong or Gapless playback still not available for Local files?
mirror88
Gapless processing will only be used when the sampling rates are the same.
Brian Hall
Southeast Oklahoma
I would like to be able to cast Youtube Music to the DMP-A6. I know I can do basically the same thing with Bluetooth from my phone, but casting from my Chromebox would be nicer.
