Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.1%
    Votes: 32 5.1%
    Votes: 163 26.2%
    Votes: 421 67.6%
I'd go as well with actives... a good pair of studio monitors (maybe a sub also). More elementary of this I cannot think of.
Me too, listening to it right now with my Mantas.
Change logs:
1. Added SPDIF output sampling rate switch delay function.
2. Optimized Roon Connect for DOP output.
3. Optimized USB DAC compatibility.
4. Optimized USB DAC output sampling rate switch delay function.
5. Addressed the issue of incorrect music service playback queue order.
6. Added Hybrid queue function (Support Local track, TIDAL, QOBUZ, HRS, DEEZER).
7. Added multiple display mode switching functions for the playback queue.
8. Enhanced the display of the playback queue interface.
9. Added custom sorting function for playlists (edit and move positions).
10. Optimized the issue where the playback queue couldn't be cleared when in random playback mode.
11. Enhanced Airplay playback stability.
12. Added main interface widget functionality.
13. Added EQ settings (effective when the input source is the internal player).
14. Added Squeeze Connect functionality(For LMS).
15. Added SoundCloud music service.
16. Added Calm Radio music service.
Control APP
android : v1.11.51
ios : v1.0.82
This is a greatly changing ALPHA version so it will not be pushed.
For those who want to try new features, you can download and install it.
v1.2.36_alpha
MD5: C47A2469D7CE3AAE7ECD20E4FC45361C
During the development of our hybrid queue, we realized we might encounter the most complex user experience task in this field, which has never been seen before. Because the A6 needs to handle various inputs and outputs, supporting third-party apps, and not all integrated services can utilize it (depending on different API characteristics), so there's a certain learning curve associated with this feature. The experience and presentation related to the Hybrid Queue functionality built into this version are the result of over a dozen modifications internally. This is the best we can achieve. Currently supported services include:Local Track/TIDAL/Qobuz/HIGHRESAUDIO/Deezer/Netease. When a third-party app is playing or the output source is not from the internal player, the playback queue remains inactive. Pressing "PLAY NEXT" often confuses users because it appears to do nothing visibly, you can't see the current playback queue. Therefore, we added the option "PLAY NOW." Unlike other players, this option doesn't replace the current queue but simply adds the current track to the top of the queue and starts playing immediately. We will also include a PLAY Queue Button located in the bottom right corner of the Control App.
The EQ function is only available when the input source is the internal player and is effective only for stereo PCM with a sampling rate lower than 192 kHz. All stereo audio with a sampling rate higher than 192 kHz or all multi-channel or DSD audio will bypass output. Of course, as some of you may want, a global bypass will also be an option. As we sincerely hope to offer users with more choices, so instead of a simple global EQ function, we configured different curves for different output setups using profile settings. This inevitably brings some learning costs. But I believe you'll figure it out quickly. Currently, it features a 15-band GEQ and a 10-band PEQ (Freq/GAIN/Q) that can be customized. While we've tested its stability, there might be a reduction in the number of bands in the final version to lighten the CPU load. This is why this version is labeled as Alpha.
I fixed my latency issue. It was the optical cable. I switched to USB. Any noticeable latency disappeared. To my ears, the sound was also a lot clearer, like in a dramatic way. I'd used the optical cable so I could alternate between the Qutest and the Wandla. I think it was engaging the DAC inside. Now I'm going straight from the streamer to my external DAC. I no longer have control of the volume but the signal is a lot cleaner. I've lost some convenience but I like the sound a lot more.
Change logs:
Control APP
android : v1.11.51
ios : v1.0.82
v1.2.36_alpha
When should we wait this update original, not testing?
Modifier les journaux:
1. Ajout de la fonction de retard de changement de taux d'échantillonnage de sortie SPDIF.
2. Connexion Roon optimisée pour la sortie DOP.
3. Compatibilité USB DAC optimisée.
4. Fonction de retard de changement de taux d'échantillonnage de sortie USB DAC optimisée.
5. A abordé la question de l'ordre de file de lecture du service de musique incorrect.
6. Ajout de la fonction de file d'attente hybride (Support piste locale, TIDAL, QOBUZ, HRS, DEEZER).
7. Ajout de plusieurs fonctions de commutation du mode d'affichage pour la file d'attente de lecture.
8. Amélioré l'affichage de l'interface de fichier d'attente de lecture.
9. Ajout d'une fonction de tri personnalisée pour les listes de lecture (modifier et remplacer les positions).
dix. Optimisé le problème où la file d'attente de lecture ne pouvait pas être effacée en mode de lecture aléatoire.
11. Stabilité de lecture Airplay améliorée.
12. Ajout de la fonctionnalité de widget d'interface principale.
13. Ajout de paramètres EQ (effets lorsque la source d'entrée est le lecteur interne).
14. Ajout de la fonctionnalité Squeeze Connect (pour LMS).
15. Ajout du service de musique SoundCloud.
16. Ajout du service de musique Calm Radio.
Contrôlez APP
androïde: v1.11.51
ios: v1.0.82
Il s'agit d'une version ALPHA en grande évolution, elle ne sera donc pas poussée.
Pour ceux qui souhaitent essayer de nouvelles fonctionnalités, vous pouvez les télécharger et les installer.
v1.2.36_alpha
[URL unfurl = "true"] http: //music.eversolo.com/dmp/ota/DMP_A6/v1.2.36/DMP-A6_R_v1.2.36_alpha_202312152138_ota-package.zip [/ URL]
Au cours du développement de notre dossier d'attente hybride, nous avons réalisé que nous pourrions rencontrer la tâche d'expérience utilisateur la plus complexe dans ce domaine, qui n'a jamais été vue auparavant. Étant donné que l'A6 doit gérer diverses entrées et sorties, prendre en charge des applications niveaux et que tous les services intégrés ne peuvent pas l'utiliser (en fonction des différentes caractéristiques de l'API), il existe donc une certaine courbe d'apprentissage associée à cette fonction. L'expérience et la présentation liées à la fonctionnalité Hybrid Queue intégrée à cette version sont le résultat de plus d'une douzaine de modifications internes. C'est le meilleur que nous puissions réaliser. Les services actuellement pris en charge comprend: Local Track / TIDAL / Qobuz / HIGHRESAUDIO / Deezer / Netease. Lorsqu'une application tice est en cours de lecture ou que la source de sortie ne provoque pas du lecteur interne, la file d'attente de lecture reste inactive. Appuyez sur "PLAY NEXT" confond souvent les utilisateurs car il semble ne rien faire visible, vous ne pouvez pas voir la file d'attente de lecture actuelle. Par conséquent, nous avons ajouté l'option "PLAY NOW". Contrairement aux autres joueurs, cette option ne remplace pas la file d'attente actuelle mais ajoute simplement la piste actuelle en haut de la file d'attente et commence à jouer immédiatement. Nous incluons également un bouton de fichier d'attente PLAY situé dans le coin inférieur droit de l'application de contrôle.
La fonction EQ n'est disponible que lorsque la source d'entrée est le lecteur interne et n'est efficace que pour les PCM stéréo avec un taux d'échantillonnage inférieur à 192 kHz. Tout l'audio stéréo avec un taux d'échantillage supérieur à 192 kHz ou tout l'audio multicanal ou DSD contournera la sortie. Bien sûr, comme certains d'entre vous le souhaitent, un contournement global sera également une option. Comme nous espérons profondément offrir aux utilisateurs plus de choix, au lieu d'une simple fonction d'égalité globale, nous avons configuré différentes cours pour différentes configurations de sortie à l'aide de paramètres de profil. Cela entraine inévitamment des coûts d'apprentissage. Mais je crois que vous le découvrirez rapidement. En fait, il dispose d'un GEQ 15 bandes et d'un PEQ 10 bandes (Freq / GAGN / Q) qui peuvent être personnalisées. Bien que nous ayons testé sa stabilité, il pourrait y avoir une réduction du nombre de bandes dans la version finale pour alléger la charge CPU. C'est pourquoi cette version est étiquetée Alpha.
Salut Mirror Je suis dans la cour d'essai sur la partie en streaming du nuage de sons. L'application native est bonne mais pour moi, soundcloud est une "usine de gaz" et je préfère de loin une véritable application comme "toxicomane"
We had our first DMP failure this week but credit to Misue @mirror88 she sorted out extremely promptly.
It was a ‘dead as a door nail’ failure.
Things do go wrong but what is important is how the manufacturer rectifies the issue.
To be candid I don’t have much experience with far eastern manufacture but Eversolo have been so far easily the most reliable .
Playing around with the alpha. The EQ is pretty fantastic, has a graphic EQ and Parametric EQ,the latter has a ton of settings. Can setup profiles and assign saved settings really quickly.
For my use (local files, airplay, apple music streaming) its been stable.
Sounds very tempting indeed !
One question: I have a DCA Stealth and there is no headphone output. Is it possible to connect my existing RME Adi-2 just as a headphone amp? Other recommendations?
Thanks for your comments !
I still have the A6 but am sending it back, not because I don't like it. I love it. But before I got it where I loved it the best, I ordered the A8, which just arrived. I don't think the move to the A8 is necessary, especially given the price difference between the two, but there are features on the A8 I'm willing to pay for. One of those is the i2s output, which I like much more than optical.
Again, just to use an external DAC?
