Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.1%
    Votes: 32 5.1%
    Votes: 162 26.0%
    Votes: 421 67.7%
I cannot find it on google store
Any other apps?
I saw it on Squeeze box forum:
I could use the spdif out to feed Hypex fusion amps ... but i need to know BEFORE i try f the knob controls the volume
So any software updates is automatically proposed by the A6?
When will be the EQ update available?
Also, i wonder why we have only 4 VU meters options available? Getting 15 of them would be nice from eversolo, does it tale hard work to design and implement?
Volume control works with usb-output, if output is not on "fixed".
should be same with other digital output, but no warranty.
Finally got this. Everything seems good outputting to an external DAC via USB, but importing/scanning music seems to take forever and that is with a 2TB NVMe SSD.
Thanks ... i just need confirmation
I canot jist try and blow speakers out of volume canot be adjusted
For testing You can downgrade amp output at hypex amp dsp, oh?
Some TB needs some TIME...
Mine scanned my 2 TB SSD in about 5 minutes IIRC. Very fast.
The EQ contains a 10 band regular EQ and a Parametric EQ that is very customizable.
You can setup individual profiles for different outputs.
It seems to work well.
It worked on these sources for me: internal SSD, AirPlay, Sirius XM side loaded app, Apple Music side loaded app, Qobuz.
The parametric EQ is great, now I can correct the non-linearity of the speakers!!!
I had added a ribbon and it screamed too loud (I don't put non-inductive equalization resistors in series, it distorts the sound).
Spyerx ,
how does Sirius Xm sound , what’s the bit rate you’re able to get ?
16/44.1 or lower ?
thanks
bk
v1.2.37 alpha version release
Change logs:
Since v1.2.36_alpha
1.Optimized stability for TIDAL CONNECT
2.Resolved occasional connection issues with SPOTIFY CONNECT
3.Added EQ L/R volume balance adjustment
4.Introduced a history playback queue feature
5.Added local track replay gain function(no DSD support)
6.Optimized occasional duplicate addition of home page components
7.Improved issues with tracks not being removed from the playback queue after logging out from music service
8.Enhanced playback order after modifying the playback queue
9.Improved random playback, resolving occasional playback queue order issues
10.Optimized display in the playback details interface
11.Fixed occasional failure in custom queue sorting
12.Optimized online streaming playback
13.Optimized occasional connection issues with Squeeze Connect
14.Enhanced Webdav editing functionality
15.Optimized occasional ineffectiveness of PEQ settings
16.Fixed occasional inability to favorite local tracks
17.Optimized EQ occasionally not being effective when switching output ports
18.Added TIDAL CONNECT MAX support
19.Optimized occasional inability to search on Calm Radio
BTW: EQ suppport internal player source(local tracks playback, streaming service, and APPs)
This is a greatly changing ALPHA version so it will not be pushed, but will push for who updated to v1.2.36_alpha.
For those who want to try new features, you can download and install it.
How to update firmware:https://www.eversolo.com/Support/support_guide/guide_target/Fh7PRJQ5IF7eq7k9e[ld]3ulg==.html
v1.2.37_alpha
http://music.eversolo.com/dmp/ota/DMP_A6/v1.2.37/DMP-A6_R_v1.2.37_alpha_202312212036_ota-package.zip
MD5: 1F2F346264C486A3B63EA340DC94131F
Control APP
Android: v1.11.61
IOS: v1.0.83
v1.2.36
1.Added SPDIF output sampling rate switch delay function.
2.Optimized Roon Connect for DOP output.
3.Optimized USB DAC compatibility.
4.Optimized USB DAC output sampling rate switch delay function.
5.Addressed the issue of incorrect music service playback queue order.
6.Added Hybrid queue function (Support Local track, TIDAL, QOBUZ, HRS, DEEZER).
7.Added multiple display mode switching functions for the playback queue.
8. Enhanced the display of the playback queue interface.
9.Added custom sorting function for playlists (edit and move positions).
10.Optimized the issue where the playback queue couldn't be cleared when in random playback mode.
11.Enhanced Airplay playback stability.
12.Added main interface widget functionality.
13.Added EQ settings (effective when the input source is the internal player).
14.Added Squeeze Connect functionality(For LMS).
15.Added SoundCloud music service.
16.Added Calm Radio music service.
Control APP
android : v1.11.51
ios : v1.0.82
During the development of our hybrid queue, we realized we might encounter the most complex user experience task in this field, which has never been seen before. Because the A6 needs to handle various inputs and outputs, supporting third-party apps, and not all integrated services can utilize it (depending on different API characteristics), so there's a certain learning curve associated with this feature. The experience and presentation related to the Hybrid Queue functionality built into this version are the result of over a dozen modifications internally. This is the best we can achieve. Currently supported services include:Local Track/TIDAL/Qobuz/HIGHRESAUDIO/Deezer/Netease. When a third-party app is playing or the output source is not from the internal player, the playback queue remains inactive. Pressing "PLAY NEXT" often confuses users because it appears to do nothing visibly, you can't see the current playback queue. Therefore, we added the option "PLAY NOW." Unlike other players, this option doesn't replace the current queue but simply adds the current track to the top of the queue and starts playing immediately. We will also include a PLAY Queue Button located in the bottom right corner of the Control App.
The EQ function is only available when the input source is the internal player and is effective only for stereo PCM with a sampling rate lower than 192 kHz. All stereo audio with a sampling rate higher than 192 kHz or all multi-channel or DSD audio will bypass output. Of course, as some of you may want, a global bypass will also be an option. As we sincerely hope to offer users with more choices, so instead of a simple global EQ function, we configured different curves for different output setups using profile settings. This inevitably brings some learning costs. But I believe you'll figure it out quickly. Currently, it features a 15-band GEQ and a 10-band PEQ (Freq/GAIN/Q) that can be customized. While we've tested its stability, there might be a reduction in the number of bands in the final version to lighten the CPU load. This is why this version is labeled as Alpha.
And the Control APP for Android tablet coming soon.
Then, once this all is over, we (poor, miserable only-dac users) might possibly get the new VUs and maybe EQs on the DAC-Z6/Z8 too, couldn't we...? After all nobody cares about us since about april this year... ;-)
Really, we would be extremely thankful to receive these as a Xmas gift from the dev-team...
Kind regards, Al.
Kind regards, Al.
Z6/Z8 will get the new VUs soon but have no EQ support. Sorry but the product attributes of DAC determine that its update frequency will not be too fast
Spyerx ,
16/44.1 or lower ?
thanks
bk
Whatever their "max" setting is, which is suspect is at best 320 or 256. I'll have to check what the device shows the bitrate as, I'm not sure.
It's not hifi :-) but ok for background music. It probably sounds a little soft, but not muffled when compared to CD sources.
So, Sirius changed their app. It's ... different. Anyway, the screen layout makes it impossible to access the "..." to change the bitrate settings (it's covered by the toolbar on the screen). But, it seems to hold settings from your account and I have it set to max on my iPhone. I know its not the mid or low as I can hear those, they sound like crap.
