M
Latest activity Postings About
    • M
      MT_bassbone replied to the thread 2x250 W class D alternatives.
      I tried the Fosi V3 monos, Topping B100 mono blocks, and the Topping PA7 Plus with the Wiim Ultra. I ended up choosing the Topping PA7...
    • M
      MT_bassbone replied to the thread Choosing DIY kit.
      I have soldered a few times but would need to either buy or borrow a soldering gun and some solder. I was looking at the Ascend Sierra...
    • M
      I definitely have the tools and likely enough skill/curiousity to make my own cabinets. I just figured since it's my first speaker...
    • M
      Is it me or do many of the kits use better parts and/or have a more linear frequency response?
    • M
      I really embrace then edges of high quality plywood. If it's made out of high quality baltic birch ply I will likely put on clear poly...
    • M
      1. Fun project. 2. Sounds like you can get more for your money.
    • M
      Probably no more than $1500 but prefer closer to $1k. I am trying to work a deal for a pair of used CSS Audio 1TD-X with the superior...
    • M
      Topping PA7+ Wiim Ultra Pro-ject DS2 CD Box I have Totem Sttaf right now but I am not in love with them and they measure horribly.
    • M
      What is your sense of keeping the speakers in the same budget range of my other components?
    • M
      Do you have other recommendations. The Mechano23 frequency response does not go low enough, right? I was hoping to get at least into...
    • M
      I probably should have mentioned that up front but yes I am trying to stick with designs with a flat pack as this is my first speaker...
    • M
      Here is from the Neil Blanchard Designs website: It just looked too stretched out to look accurate so another member adjusted the...
    • M
      Is that something I did or the machine did on its own? Is there a different setting to try?
    • M
      sure
    • M
      Not sure about well. Here are the results from the room correction on the Wiim Ultra. I didn't like it so I turned on the graphic EQ...
  • Loading…
  • Loading…
