Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.1%
    Votes: 31 5.0%
    Votes: 162 26.1%
    Votes: 421 67.8%
I realized. xxxx! do you know what that could mean? I've opened the site 5 times :(
but pressed nothing on it
The site is very insecure and probably quite easy to hack.
It has a Javascript that loads:
Malware "JS:Trojan.Cryxos.12004 (B)" in F:\Temp\xiao.js
(SHA1: 3C9E21E6B0DB0E46E8806E161CB14ED4AD6CFC87)
EDIT: "index.php"
has a very interesting one-liner:
snippet of one of the JS:
@mirror88
Hi. Just bought the A6 and its fantastic. I just ran into one problem. For me the operating via iphone is terrible. So I bought an Ipad 2. Now I realize this one is not exactly the latest version but I thought it would suffice. The UI looks much better but the searchin engine is incredibly slow. Sometimes I have to wait 30 seconds for a character to appear. I tried a few things like not using the WIFI but connecting it to my Iphone using the sharing option but it does not help. I also completely reset the A6 and the Ipad but without any result.
Question: can someone tell me why the search engine is so slow and possibly have a solution?
No issues with my iphone at all. It is only buggy when I have the Low Consumption mode enabled on my iphone (lag in cast mode). No issues either with my ipad
Its really fast . Both in Android and iPhone. No lag at all in search engines. Probably you need to check the Wifi / internet settings.?
internetspeed is ok about 200 MB per second. All apps work fine as well as the attached hard drive. It turns out that only the Apple Music app struggles. Amazon music no problem Qobuz no problem.
hi
will there be an software update to have atmos via hdmi out?
Just reading that this is pushed by many provider. think that could be great on some concerts or specific albums?
thanks!
somehow unbelievable that you have an 3 month old device for nearly 900 eur with hdmi out specifically designed to stream audio files and nothing else and then it doesn't support that?
one device for every little xxx and another one and another one and in 50 years our little planet is....
Thanks to Mirror and Eversolo, perfect integration of Amazon music in the latest version just like Qobuz and Tidal or Deezer, it's super complete now.
Is your DMP-A6 is playing back Amazon Ultra tracks at proper resolution or at 16 bit/48khz in Opus Codec ?
For me it is a miss also although I knew this by research. I think it is because this device is developped for audio purist. They tend not to like anything besides stereo.
Native Amazon music integration has a parsing strategies issue during playback lead to selecting an unexpected stream in some cases, which will be fixed in the next version.
Gapless playback of Amazon music will also be optimized.
Should be within a few days.
I noticed that as I have Amazon and Qobuz, thanks @mirror88
hi sorry maybe stupid question but not my mistake that there's not one word in the manual.
do we have a table (of what is possible, quality Hz bit... , remote control, which app to use, Playlists, likes, advantages or disadvantages.. ) or at least an order in terms of quality what's the best way to stream?
how should I know that?
music service
music app
music connect
Thanks!!
music service
music app
music connect
Thanks!!
As long as you choose a ‘lossless’ codec ie 44.1 there won’t be any difference, the D`mP tells you the sample rate and bit depth so you can always check exactly what you are listening to.
Radio streams for example can vary hugely.
thanks both! I thought with that device I'm starting my 192 journey that will never stop, not 44.1...
anyway I will try it. first will be flac files from the nas so no possibilities and then later qobos via the 2 possibilities..
