Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,172
- Thread Starter
- #201
Thanks for commenting in this thread twice!Ask yourself what are you trying to accomplish exactly.
Last time, you worried about different frequency response at different level. I measured and no issue whatsoever across a wide range of DACs.
This time it's warm up/break in. In either case it's not significant to cause any issue by your own measurement.
What do you want to know and what exactly is missing?
I don't think you should be buying anything more just for the sake of doing it. You don't need to. You should be listening to music.
Appreciate it!
Simple, I want to know if DAC break in could happen or not and how to measure for it. : )
My question have been consistent. Why I prefer E30's highs when I first listen to X16 with my stereo setup?
Other than the obvious hearing, mood, health, bias, memory, and volume matching problem, any other explanations, like burn in/break in, possible?
How stable are all the components inside a DAC? Could any of those cause the initial high freq issue I observed?
You are the expert here.
You have plenty of different DAC on hands and I supposed you can easily access brand new DAC?
Maybe you can save me plenty of time and money if you can help put this to rest?
Find a few brand new DAC with similar interior components of x16, do some first time boot measurements/if possible, listening tests, and see if they all perform perfectly right out of factory.
Thanks a bunch!
