CHORD M-Scaler Review (Upsampler)
Rate this product:
    Votes: 358 88.2%
    Votes: 13 3.2%
  • 3. Fine (happy panther
    Votes: 7 1.7%
    Votes: 28 6.9%
firedog
If someone wants to upsample with lots of taps, just buy HQ Player and install. It will also do it, and it costs a tiny fraction of this HW.
gvl
SoCal
Does anyone care to hypothesize about why the Topping DAC was so much worse? Is that due to the massive jitter that the SPDIF receiver just can’t deal with?
Very likely, especially considering high sampling rate. There’s no ESS chip with its jitter fighting gizmos in the D70s
For these devices, must use an external linear adapter that costs at least $3,000 or more for a BNC cable (x2) and a similar price. :facepalm:
I hope you are sitting down as the cost of the Nordost TYR 2 coax cables I used for testing is US $1,750 each! So that requirement was more than met.
@amirm apologies if you’ve stated this and I’ve missed it. Did you test this using dual BNC into the Hugo 2 RCAs in any of the tests?
Yes of course. See this graph in the review:
As you see, it was the "Dual Coax" configuration at 16X upsampling. The input by the way is 3.5mm! Owner kindly provided a special dual BNC to this 3.5 mm connector.
Blumlein 88
So kind of on the low end for Nordost right? ;)
Would have gotten good results with Nordost Odin 2 Reference. 1.25 meter for $12,999. Remember you will need two of them.
So the cable would cost near 5 times the device tested here. Always put the most money on the most important part. People always try and low ball it and well you see what happens.
/sarc
Geert
It is core to Rob Watts' marketing talk on these products. Just watch any of his videos.
Before we start the 300dB discussion all over again, check
The problem occurred even when M-scaler was in pass-through mode with sample rate then being 44.1 kHz. See bottom of the screen snapshot for sample rate:
It is very strange as bypassing M-Scaler completely removed the issue. Maybe its voltage swings are different or something that is causing some problem.
Reactions: gvl
Blumlein 88
I mentioned it earlier and maybe Solderdude did too. He is claiming to hear differences in filters that seem to only differ from each other at levels of -300 db. Not saying he can hear at those levels.
voodooless
Netherlands
So what’s the difference? He either can hear content down there or he can’t… the rest is just semantics.
Blumlein 88
Well yes, but you need the magic and the mystery. So he has filters he claims (without proper controlled listening I assume) he can hear as different. The only measurable or even theoretical differences are at -300 db. So he isn't claiming to hear that, he is sort of leaving the door open for a God of the gaps argument that something more is involved so his incredible taste in hearing music can hear a difference that we cannot measure. When of course a rational person says, "if the only differences are -300 db, even in theory, and they sound different you either hear -300 db or you aren't hearing what you claim."
voodooless
Netherlands
That is indeed all we need :) Move along, nothing to see hear…
pma
Prague
"What is this?" Groundloop! "This" and noise floor elevation, both are products of the groundloop.
xaviescacs
La Garriga, Barcelona
My question is, there was really a chance for this device? What's the theoretical benefit of upsampling? Is this just a digital filter for 5k?
