When I first heard the Vivaldi system it was because I walked into a random room at an audio show. The only product I saw was a pair of Wilson speakers (dCS use Wilson) and some large amplifiers (brand unknown). I'd never heard of Vivaldi as it was brand new, and the dCS people were sitting in front of it. So I did not know the source until I asked, and it could have been coming from some other sources they had there. So it was not controlled, but it was blind and not expectation biased. It was just one of those extremely rare 'Wow' moments I can count on one hand.
I did not own Chord at the time, I own a Mojo and have heard Dave several times. I may have an opportunity to listen to the M-scaler in about 2 weeks, but I have no intention of buying one, so there is no money to be saved. I'm just curious about it. I've not said the M-Scaler has any benefit as I've not heard it in use.
I just read what Rob Watt wrote - basically the high jitter is on purpose and irrelevant sonically for the low rate upsampling, and the M-Scaler is really intended to be used with x16 upsampling using the 2xBNC supplied into the Dave DAC. I assumed as much in an earlier post.
What Robb is saying could very well be true, but unless it creates an audible difference that can be reliably detected in properly controlled blind listening conditions, regardless of what is measured, it is absolutely moot. That is all I care about, separating claims and implied benefit from those that can be demonstrated with blind listening testing. The differences between the best DACs tested here and those that perform below SOTA doesn't matter at all in terms of audibility. Why we do like to see great engineering even if it becomes academic is that it brings with it a trickle down effect and improves the class of products altogether over time.
So even though the last few Topping DACs, for example, all measure transparently and have for several years unless I'm missing something, those are actually relatively affordable and can be used for a very important purpose in the audio chain. Something like the M-Scaler is by way of comparison obscene in terms of cost, and additionally, there does not appear to be any valid reason for it to exist at all. Other than to generate profit.
It is attempting to solve a problem that doesn't exist in any meaningful sense other than as a mathematical, theoretical construct that perhaps, just might, under the very most auspicious moments, align with a great many other factors, to possibly, maybe, create this tiny effect when the proper configuration of the stars and planets align. But of course you need to spend thousands of dollars to eek out that 0.215% improvement in sound, a theoretical improvement mind you, and just maybe and only if your cables are not holding your system back. But wait, what about the power coming into my house? How dirty is it? And my god, what about the clocks in my DAC? How many sources of inaccuracy are there? How can anybody enjoy music under such conditions? Don't you people know how much better your music sounds when you spend that additional $20 000? Why even bother otherwise? All of that digital noise, it is ruining the music and we all just put up with it? We let companies like Topping, and SMSL, Gustard, Schiit produce affordable gear that doesn't give us the benefits of the M-Scaler? I question why we even go on under such conditions.
I'm being deliberately ridiculous, but I would feel comfortable saying that creating a product like the M-Scaler designed to solve the "problem" that it purports to address, and for the price it sells for seems rather ridiculous as well. For the record I have owned a Mojo and was on the first review tour of the Hugo 2. This tirade wasn't directed at you balletboy. Your posts have been reasonable and you have not been making wild claims so this was really not aimed at you.
