Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 6,715
- Likes
- 8,067
8361 as a usernameThe missing attachment...
Now that's dedication
Don't want to derail the thread just clarify a misconception. The Dutch 8c is a 3 way speaker not 2 way.The D&D 8C goes lower, at an extra cost. Though they seem to be pretty good speakers, probably they have by design a little less coherence in their spatial abilities than the 8361, they are a 2 way speaker, not a 3 way coaxial point source.
Yes, conceptually this is what is done to equalize woofers/subs. I do this often, but with sealed subs. I typically use a Linkwitz transform, which specifically equalizes the driver with a 12dB/octave shelf to compliment the driver's natural 12dB/octave mechanical highpass response. I use a steep DSP highpass about one octave lower than Fs to limit the driver excursion and distortion, and most importantly damage. I do this sealed only. Ported systems use the port to assist the woofer's output at the port resonance, they actually help the driver to minimize excursion at resonance, but below resonance the driver rapidly increases excursion (you can see all of that in the excursion vs. frequency graph I posted). Keep that in mind because you misinterpreted what I said:(a) EQing to boost bass at the cost of a flat response (e.g., setting a 2dB shelving filter at 100Hz using GLM's SCP)
(b) EQing to boost bass in line with a flat response (e.g., perhaps setting multiple filters...)
(c) Some combination of (a) and (b)
No, the driver's dramatically increased excursion is the source of distortion. Also, EQ will remove the benefit of lower driver distortion provided by the port. And introduce more port distortion due to the higher wind velocity in the port.I hadn't thought about excursion, thank you. It seems that I at least need to be cautious of:
(a) insufficient power being delivered to the driver (causing distortion)
(b) more power being delivered to the driver than the driver can handle (also causing distortion but further potentially damaging the driver)
@8361AM AM : You know, this drawing doesn't tell much, we have understood your questions now.
@8361AM AM : There is absolutely no reticence among us to answer them, and IMO you've got a lot of answers yet from each of us.
@8361AM AM : Don't get too focused on a few Hzs in the low bass ; for 90 % of music, it doesn't matter.
@8361AM I have no idea why everyone is confused by your query, it seems perfectly understandable and reasonable.
I was beginning to doubt my sanity or otherwise...
Even if the difference is subtle, it'd make me extremely happy to demonstrate to you all that the 8361A could be EQ'd to extend to 29Hz rather than 36Hz at ± 1.5 dB. Might members be prepared to support me in this?
Holdingpants : of course, the room bass reinforcement can be very effective, but the W371 expends the 8361 FR in the bass, no surprise it goes flat down to 20hz and maybe a little lower (but is it really necessary ?)
8361 AM : as for the movies, if you really want realistic very low bass to reproduce, for instance, explosion or battle "big" sounds, you'd rather add one sub (or even better two smaller subs) equipped with a calibration system. That would be a better option.
By the way, tell us more about your room, its dimensions, volume, type. Without knowing your room and the SPL max you need, it's impossible to help you more than we try to do.
I am worn out now, but my challenge to this would be to consider how similar the 8361A and 8260A are. Both are ported and both share very similar enclosures. Unless the bass drivers differ meaningfully (or otherwise), should the 8361A not have the potential to behave more like the 8260A? Even if the difference is subtle, it'd make me extremely happy to demonstrate to you all that the 8361A could be EQ'd to extend to 29Hz rather than 36Hz at ± 1.5 dB. Might members be prepared to support me in this?
you could easily make it flat down to 20Hz or even less if you sacrifice a little loudness (you don't need).
But it probably goes down there anyways with room gain?
But you are right, room gain can add 6 dB, and then you can now hit 81 dB down to 20 Hz, and a speaker that was -4 dB at 20 Hz isn’t bad, so you could actually say you were trying to hit 85 dB down to 20 Hz instead of the factory tuning of 65 Hz at -4 dB @ 106 dB. (All at 1 meter).
but a closed speaker doesn't go lower, all things equal.
