Tovarich007
- Joined
- Jan 31, 2021
- Messages
- 438
- Likes
- 692
A sealed loudspeaker will have more output than a ported one, below the port tuning frequency. Since we're looking specifically for increased output down there, sealed is about the only option.
NB - the other option is to extend the length of the port, which will decrease the tuning frequency. This is much more difficult to do well than simply sealing the port. Ideally, you'd increase the cabinet size to maintain a somewhere-near flat response. Playing around in WinISD or Hornresp will be educational for those following along.
Chris
Yes of course, due to the gentle progressive roll off of a sealed design, I never said the contrary, but a sealed design doesn't go lower in absolute terms than a ported one. But the more progresive roll off and thus the relative higher output under the tuning port frequency has a price in SPL, power requirements, distorsion, and that's not so easy to fix properly without a simulation, tests and measurements, for a speaker not originally designed to be sealed.
Genelec has always released ported speakers. it doesn't mean they can't do other types of designs if they will, because this company has the expertise to design any type of design. But they consider it's the best compromise, and they don't do so only because a ported design is less subject to thermal overheat risks, being opened, even if they surely have taken this criteria into account.
Whatever can be the more or less satisfying results of such a transformation, It will certainly cancel the constructor warranty and services in case of problem.
For many reaons, I'm not sure it's a good idea to suggest to make such a modification for a person like 8361AM, who is quite sympathic but evidently not an expert or a technician.
