- Joined
- Dec 12, 2019
- Messages
- 13,594
- Likes
- 30,289
This tablet appears to have been extensively digitized.I know not what digitize mean?
(image from Wikipedia)
Sorry... sorry!
Needs to be defragged.This tablet appears to have been extensively digitized.
Sorry... sorry!![]()
Fast recovery is the preferred way to go. Too much headroom and loud clicks/pops will just clip gain stages in the following chain.You can skin this cat with overhead, or with fast recovery. For the event itself the data is already lost, so it’s not necessary to reproduce garbage with exacting fidelity - you just don’t want a lingering ill-effect.
Can recovery time be observed or measured?Fast recovery is the preferred way to go. Too much headroom and loud clicks/pops will just clip gain stages in the following chain.
My preferred, though IIRC, for some topologies that can suffer blocking overhead is likely the way to go.Fast recovery is the preferred way to go. Too much headroom and loud clicks/pops will just clip gain stages in the following chain.
Yes. Use a Test Signal with a 1 kHz sinus and add a very short rectangular pulse of lets say 20 dB higher amplitude. Run it through the preamp and capture its Output. Check the length of the pulse and measure time until the sinus is reproduced as expected.Can recovery time be observed or measured?
