HI, thanks @DWPress
It's a 7.1 ch system, with 2 of the 8 Okto channels for Ch 1 & 2. And those are bi-amped. Too bad Okto doesn't do 10 channels
I had been running AES 1&2 from Okto to Venu360 and doing all the (stereo) crossovers and roomEQ in that.
So I need something to take Ch1 & 2 from Okto and split into LF and HF. Could be done with active xovers between Okto and the 4 ch Hypex amp, or passive xovers downstream of the amps.
The referenced active xover looks pretty good, but is 3way, and (maybe?) a bit more than I'd like to spend...but I am considering using that with just two crossover cards in it.
So, I'm curious if there are other, better options out there, something commensurate with the Hypex and Okto performance.
Having some kind of xover 'card' feature inside these amps would be a killer idea, though.
Thanks!
Thanks!
