This is spot on. Hype XLR inputs are properly designed, and won't suffer ill effects from XLR cables not wired per Hypex recommendation.Even in the case of the Monoprice cables being wired incorrectly sometimes, whether it will cause an audible issue is a crap shoot.
For those who know they have a ground loop issue and are getting new cables, I would absolutely positively recommend getting a cable built to exact spec.
For those who have never had a ground loop issue and just want to try whatever cable might work, if you don’t hear a hum or loop issue, etc then the wiring with regards to grounding/pin 1 is not an issue.
Internally I wire the amps the absolute best/correct way so there is no second guessing from that respective. Past that whatever works for a customer works, obviously.
I guess I am coming from the point of view...why spend good (and or more) money on cables that can knowingly introduce hum on ill-designed devices, when I can just get a cable that solves the issue and is cheaper all at the same time? Or spend money at a cable firm that I have to tell how to build it properly (when they should know already)? That I can move from the Hypex to some old non-AES84 compliant device without future worry?
Anyways back to amps.....
