@Buckeye Amps
I have one of your Buckeye 8-channel 502's (from MWAVE, thank you very much) and a different 8-channel 252 amp, both installed in my HT rack. *Also have a 98 pound 7-channel A/B in there for tactile, but that's another story.
My left and right speakers are 4 ohm (JBL CBT 1000 @ 6000W peak), but my center is 8 ohm (JBL CBT 70J-1 @2000W peak). I happen to have an unused amp channel on the 502 and the 252 right now, so I thought I would ask.
Question #1
If I want to use 2 channels of the 502 for the 4-ohm mains, but I want to bridge tie load (BTL) one 502 module for the 8-ohm center, do you think my Marantz AV7703 pre/pro using Audyssey will have enough correction (0-12db) to offset the difference in gain while using XLR interconnects? It's not a big room, so I also have room gain.
Question #2
Much more complicated,
Step #1
Say I were to use RCA outs, like outputs from a MiniDSP 2x4HD, to one of the XLR inputs on one of the amplifiers. I would need a special XLR wiring to do this, without using an adapter. This I've seen posted before.
Step #2
Let's also say I would like to BTL, at the same time, using a custom XLR to externally do the BTL, while simultaneously doing a RCA/XLR conversion on the same I/O as the load (8ohm).
Would this be possible through proper XLR wiring alone, or would the module require internal BTL wiring and custom interconnects? If so, could you provide a simple schematic of how to do it? Best practices.
This obviously isn't a case where I would ever "need" this power, but one where I would like to take some measurements, and maybe later impress some folks who are very much into attending GTG's specializing in high SPL . All cautions taken of course. Safety first.
TIA
