Buckeye 3 Channel Purifi Amp Review
Rate this amplifier:
    Votes: 19 6.8%
    Votes: 68 24.5%
    Votes: 152 54.7%
    Votes: 39 14.0%
Now Dylan, can you imagine new business prospects?
You can start marketing binding post upgrades: "Take your sound to a whole 'nother level only for 59.99 a pair!"
You can also offer premium upgrades: "oxygen-free single-crystal copper", silver-plated, gilded, pixie dust-coated... :)
Dylan, any plans to build a 5 channel Purifi - can it fit in 1 case?
Cheers Al
Cheers Al
It’s somewhat on my radar, though I am a little reluctant since I myself find it very difficult to recommend spending extra money on Purifi amplification for surround sound channels.
I'll let Dylan correct me if I'm wrong but 5 channel Purifi would require a different or dual power supply. The one in 3-channel amp is already maxed out.
I was torn between ordering 3 channel or 5. My setup is 4 full-range towers and a fairly large center channel, so I went with a 2+3 channel amps.
The amps are stacked on top of each other, as they don't get hot at all. The only nitpick I have is the difference in their sizes. I'll take and post pictures later.
If I were to do it again, I would have asked Dylan to build the 2 channel amp inside a 3-channel enclosure. This way both amps would stack nicely.
Yes, for a five channel Purifi, you’d need either dual SMPS1200 or an SMPS3k.
It could be done and fit into a 17” wide case. But again, it’s hard for me to bring a product out that I myself would not use or endorse as a hobbyist if money is a consideration.
A lot of people listen to multichannel music and in those cases, the surround channels are not bandwidth limited and are losslessly compressed and deserve as clean an amplifier as the front channels, IMHO.
In fact, most Blu-ray and UHD content offers lossless compression for all channels.
If we are talking garden variety Dolby Digital or DTS, those employ lossy compression schemes. If we are talking Dolby Pro Logic, the surround channels are bandwidth limited. But those are older formats.
I guess what I am trying to say is that the days of treating surround channels like second-class audio citizens have long passed!
Well, unless you are talking streaming . . .
I could see use case for critical multi channel music usage...but that's about it for me in terms of 5ch Purifi recommendation.
It's not about the quality of the source in regards to loseless movie soundtracks. The fact is in real world setups, when listening to even the best TrueHD/Atmos track, I would make a bet that you would not hear the difference between say a Hypex NC252 and a Purifi 1ET400A driving the surround speakers. Money better spent elsewhere then worrying about having Purifi for surround speakers.
I have 2 individual 20 amp circuits (serendipity by the designer/home builder in 1968 that happen to meet my needs when I moved in in 2022) near my stereo gear.
I have a UPS on each one.
There are 5 Quintuplet NAD 2200's (resto-modded [circuit design not changed, just modern components]) by Peter @ QuirkAudio.com (one of which was tested by Amirm here: NAD 2200 Vintage Review [see the LAB input test]), as well as the rest of my gear splitting the load between the 2 outlets.
I am currently running the system 2.2 (a pair of Dahlquist M-905's and a pair of self customized [passive 12" dual voice coil subs for up to 80 Hz {that can be easily be setup as 4 OHM or 2 OHM circuits)]).
As I switch things up a bit from time to time, I run at least 2 of the 2200's in bridged mono (4 OHM mode) and sometimes one or another in stereo 2 OHM mode.
I have been collecting the NAD's with the intent to build a larger system 2.4 or 4.4 (QUAD? I have 2 APT/Holman Pre-Amps that, together, can do that) but have now moved into a smaller home.
I have been mulling over a pair of resto-modded (if Peter at Quirk Audio would take them on) Proton D1200's (an uncommonly attractive amplifier to me [mostly due to the meters]) for my subs.
NAD's Bjørn-Erik Edvardsen's had a big hand (collaboration) in the clever circuitry designs that gave the Proton D1200 amplifiers (very similar to the G amplifier topology of the NAD 2200's) the ability to perform like higher end amplifiers while keeping their cool.
HMM, BUCKEYE's 3's (and possibly 5's) are also intriguing, as they are some of the very, very few CLASS D that I would consider.
And they would reduce massive amounts of hiding clutter (clutter to my significant other, at least). A very important consideration since I became married (for the only time) when I was 48 (now together for 18 years).
And if meters were available (as an option, perhaps) from Buckeye, on some of my sub woofer channels...
My amp plans could drastically change.
FWIW, someone just posted a video review on YT.
TL;DW he experienced lower speaker levels than with the Emotiva he came from but was pleased by what he heard.
Different volume levels is just a matter of gain I believe. Most Emotiva amps have a gain of 29dB (1.6v to reach max volume) and the Purifi is between 15-25 depending on the setting set at.
My thoughts exactly and commented the same on his video. If I understand Amir's review, the Buckeye requires around 2 volts at high gain for full power.
I like the 5 CH idea for simplicity for someone who just has a 5.1 setup.... For me i would prefer my LCR+ side surrounds with the same headroom.
If that is set up as a WATT meter and was reasonably accurate, I don't think that it looks too busy, as it seems to have a way of being able to adjust inputs to the same output level.
I liked all but the 4 white lights in the center; I agree that being able to calibrate your line level input to watts output (at whatever impedance you pick) is a great feature. I would guess that showing clipping may not be an option, but most of us i suspect would be buying it for the needles dancing.
Reactions: EJ3
There appears to be several or more peeps looking for a class D amp with big VU meters. A common request although finding suitable big VU meters is apparently not so easy. :D
Sorry, a little bit out of the scope of this thread, but I just noticed your above comment.
As you have been already well aware of, I am one of the people having "A common request although finding suitable big VU meters is apparently not so easy."
Accordingly, I went into DIY construction of 12-VU-Meter Array in my multichannel multi-driver multi-amplifier DSP-based fully active stereo setup.;)
Reactions: EJ3
Note: I am an end user audio enthusiast and I have no conflict of interest at all with any of the manufacturers, import companies, distributors and audio shops relevant to this post. This post is not intending to intensively share objective and/or subjective evaluations of the audio gears, but I would like to share about how carefully the manufacturer(s) avoid magnetizable metals in SP selectors and line selecters.
Even though I shared this info here in the remote thread, just for our nice reference, let me share again on this thread; I do hope your browser would properly translate these web pages into English.
https://audiodesign.co.jp/
SP selectors;
https://audiodesign.co.jp/HAS/HAS-3S.html
AMP + SP selectors;
https://audiodesign.co.jp/HAS/HAS-33S.html
Line selectors;
https://audiodesign.co.jp/HAS/HAS-3L.html
Balance Line selectors;
https://audiodesign.co.jp/HAS/HAS-3LB.html
Dual Line selectors;
https://audiodesign.co.jp/HAS/HAS-33L.html
Reactions: MCH
This was not expected and was not an attempt to have a known/flawed product pushed through review.
While we did robust testing during development and prototyping, I cannot account for why this issue was not identified or observed early on. But I do take full responsibility.
As Amir briefly acknowledged, now that we are aware of and able to reproduce the issue on our end, we have been testing furiously to identify the exact cause so we can produce a fix.
Transparency and communication with the community has been one of the "pillars" I've tried to build my business upon. As soon as we identify the exact issue and the appropriate fix, it will be implemented ASAP, including for current customers as needed.
To me that looks like soft clipping.
SP selectors;
AMP + SP selectors;
Line selectors;
Thank you for sharing.
Wanted to ask you, and i think it might still be relevant to this (multichannel) thread. Do you know any source of a similar multichannel analog volume control/preamplifier? Feel free to answer via pm if you prefer.
We can find several low-quality (cheep) line-level passive stereo or mono (not multichannel) volume controllers (better to say attenuators) in the market, but all of them would not be recommended for our HiFi audio use, as you may fully agree.
Rather high-end HiFi stereo preamps and HiFi stereo integrated amps, therefore, would be our choice for line level volume control, but almost no "multichannel" ones available in consumer market; I am not so familiar with professional and PA market, but I know pro and PA audio gears are usually inferior to high-end HiFi home gears in terms of total sound quality. At lease for me, almost all of the AV preamps and AV amps would be also excluded in my audio project in terms of sound quality.
Furthermore, we do not need "powerful amps" to drive our midrange-drivers tweeters and supertweeters, but we definitely need excellent HiFi high-S/N low-distortion amps.
My recent discussion here and here would be also of your reference, I believe.
These points and discussion are part of "my rationales" for the utilization of proper and suitable (high-end) "integrated amplifiers" suitable for each of the SP drivers after the multichannel DAC in my multichannel multi-driver DSP-based fully active stereo audio system. Please also refer to my post here for the wrap-up of my long and intensive amplifier exploration journey. This post would be also of your reference for the use of "integrated amplifiers" in our multichannel active seutp.
Reactions: MCH
I would love to see actual evidence for that statement. It is a common part of audiophile folklore, but...
Some threads at DIYaudio looked into the relative amount of power required for amps driving midrange and tweeter compared to woofer and subs in an active setup. There is also some info from Rob Elliot on the topic in which he looked at the average power as a function of frequency contained in several music tracks of differeing music styles - he found it to be highest for the midrange band. The power required certainly depends on the sensitivity of each driver, and that will change from design to design and typically the midrange above 500Hz and tweeter have higher sensitivity compared to a woofer. As a result, the demands of the tweeter and midrange typically require lower average power but not lower peak power. This in turn relates more to the required power supply capabilities than amplifier module power rating. In terms of a linear PS it would mean that you could use a transformer with a significantly lower VA rating, but still having the same secondary voltage as that for other channels e.g. the woofer.
