ctrl
The listening test of the Be version is very clear about sibilants:
"otherwise there may appear problems with a sharp transmission of sibilant sounds "
On that point, Be is better than aluminium but not as good as silk.
Well, listening tests without exact specification of initial conditions or measurements, we only know that the woofer was "mated with a tweeter at 2.5 kHz by fourth-order acoustic filtering", should always be treated with caution.
If the 6-8kHz range was slightly lowered in one tweeter, or if this range was neutral or slightly raised in the other (compared to the average sound pressure level), then it would already explain the different listening impressions.
In addition, the silk dome emits much less "sound power" at 8kHz than the Al-dome, as can be seen in post#11.
This is less a question of tweeter quality, but rather a question of crossover tuning. Which is also said in the review:
...carefully handle the formation of the frequency response in a certain range, otherwise there may appear problems with a sharp transmission of sibilant sounds.
