- Joined
- Jun 5, 2016
- Messages
- 2,898
- Likes
- 4,743
That is a false statement. It obviously doesn't control 100% of the bass management
You can’t have it both ways. My statement was clearly true as written by your above admission.
Unless the software keeps each channel together (I.e. the target curve for each channel encompasses the whole channel, not just a limited bandwidth of it with the rest of it stuck elsewhere.
BTW one could add highpass and low pass filters to channel curve components as early as Dirac 1.
That's nice, but I hate to tell you, without any experience with MQX, much less extensive experience with it, those reviews are largely now obsolete for any high end user of Audyssey.
They remain accurate to the core functionality, which hasn’t changed. To the extent they were obsoleted, it was by the iOS app that allow one to use the core good parts of Audyssey and ditch the terrible default target curves.
While it's still not as easy as I'd like (I wish they'd allow the import of a frequency response curve) creating the target curve is dramatically easier and more accurate than the app.
Correct me if I’m wrong, but MultEQ X doesn’t even allow you to shape the target curve directly. You have to use the dumbass abstraction of faux PEQ bands. Therefore, it’s actually a step backwards from the $20 iOS app, which admittedly does need a “copy curve” button.
Speaking of PEQ's, people were rightly excited when the HTP-1 came out and allowed 16 PEQs along with Dirac.
For different reasons though. The utility of PEQ on HTP-1 (along with Storm, Datasat, etc) is to “precondition” prior to running room correction. One use case is in place of a separate DSP for assisted speakers. Another use case is to take down a a big peak that’s throwing off level/volume calibration before EQ.
Note that I’m writing about actual utility, not what excites people on the internet.
32 possible mic positions. This provides a substantially better spatial average which will result in better and more repeatable corrections.
Does it? Per the Geddes and Blind AES paper 5 points generally suffice. If you want to take 32 different measurements of 15 different speakers for one calibration good for you I guess.
I don’t have time or inclination to address the rest point by point. Someone may find them useful and even worth the bizzaroworld consumer-hating license terms. Every product likely finds some fans. However, to me the story of MultEQ X is one of obvious omissions, far too little too late functionality, with unacceptable license terms being the nail in the coffin.
