It's always given me a value in the past...
what version of DeltaWave are you using?I'm occasionally getting this error when I try to play delta file, any ideas why? I can "fix" it if I swap between reference and compare files i.e. I still use the same files.
2.0.16what version of DeltaWave are you using?
Hmm, strange. That line number in 2.0.16 shows nothing that could produce the error you posted. You said it only happens occasionally? Any specific actions you can think of to try to reproduce it?2.0.16
It seems to happen with certain files, not occasionally. I have recently recorder files with Audacity, all identical length etc. And comparision of some of them causes the error to appear. I have one file pair that always causes it, I just load them, press match and when finished try to play delta and the error appears.Hmm, strange. That line number in 2.0.16 shows nothing that could produce the error you posted. You said it only happens occasionally? Any specific actions you can think of to try to reproduce it?
I have also noticed this: the error appears only when stereo mode is selected, the same files work fine with L, R and L+R. And they work in stereo if reference/compare files are switched.
I'm getting a server not found message on that link. I was on a VPN. Turning off the VPN let it work. Just in case others run into the issue thought I would note it.Quick fix v2.0.17 to address the issue reported by @TimoJ: https://app.box.com/s/hlglgy3aj39rjfxu343fho4t0cdrq9v8
The problem was with the difference file playback in stereo mode, where with some input files, one channel turned out to have fewer samples than the other after being trimmed which resulted in 'index out of range' error.
sudo apt install wine
sudo apt install winbind
env WINEPREFIX=$HOME/winedotnet wineboot --init
env WINEPREFIX=$HOME/winedotnet winetricks --force dotnet461 corefonts
env WINEPREFIX=$HOME/winedotnet wine DeltaWaveSetup.exe
0080:err:winediag:is_broken_driver Broken NVIDIA RandR detected, falling back to RandR 1.0. Please consider using the Nouveau driver instead.
env WINEPREFIX="/home/XXX/winedotnet" wine-stable "C:\\Program Files (x86)\\PKAudio\\DeltaWave\\DeltaWave.exe"
The problem with the "simple method" is that it is based on only measuring drift between start and end of the recording, so less accurate but faster. The reason it's being suggested is that other points in between these two produced large error. That indicates that the recording is either noisy, or time is not consistently drifting over the whole recording.In my latest runs to compare DAC/amp dongles playing the same song I've been seeing more frequent failures of the primary drift correction method, followed by a dialog popping up asking if I wanted to use an alternate method. This second method seems to always run faster and give better results for my material. Is there some way I can force DeltaWave to skip right to using this alternate method and not even try the first one?
But also, regardless of method: can I force some correction-related value manually in order to (hopefully) get an identical result on later re-runs on the same pair of files, like if I write down what the Phase Offset turned out to be last time and try to reuse that one? (I like it as a candidate for a reusable value since it's shown with 6 decimal precision.)
nice , thanks3. This version also adds the option to save audio WAV files as 16- and 24-bit integer PCM samples, and as 32- and 64-bit floating point:
A new version of DeltaWave is available for testing, v2.0.19:
1. This version adds the option of automatically removing the phase effects of a minimum-phase DC filter by attempting to solve for the filter parameters (discussion). The automatic DC filter calculation and removal is configured under settings:
When (auto) frequency is selected, DeltaWave will try to solve for high-pass/DC filter parameters, as part of the Match operation, and automatically remove the effect of any such minimum-phase filter. If a number is entered instead of (auto), the DC filter will be removed with that corner frequency. This will be applied to all comparisons, until "Undo MP DC filter" option is unchecked. Computed filter frequency will be logged in the Results tab for your reference:
2. The option for computing the frequency of such a minimum-phase DC filter is also available under Process->Compute DC Filter correction menu. You may want to uncheck the "Undo MP DC filter" option when using this, as the menu will work on the result of the match operation. If this operation already undoes the DC filter, then the menu command wlil not find much left to correct
Dither will be applied at the bit size selected in settings (or not applied if unselected):
Hi @pkane !
Thanks again!
This may be an user error, but I can't get the automatic DC filter removal to work:
It detects the filter:
Still nothing happens:
But if I do it manually with the compare file...
... and invert the phase...
... it works ok:
My first thought was that this was due to the decimal separator (Comma), but it works the same way even if I change it to a full stop.
And just like you, I don't want to mess up the reference file, but it works too when testing:
Without inverting the phase:
The result is the same:
