I uninstalled and reinstalled and copied your settings. I don't know which of the 2 fixed it but now working correctlyExcept in my case, it was computed automatically, in 15-20 seconds. When DW reports 1.5Hz or greater HP filter frequency, this means it didn't find a solution. As I said, I'll add the logic to give an error message for this in the future. For now, it seems something isn't set correctly in your configuration.
First, try to uncheck drift correct -- you don't need it and it takes a lot longer to do the initial match.
Then, try using all the same the settings I have here. Change FFT size for Spectrum to 1M, 32k doesn't have enough resolution below 1Hz to see or measure the details:
Suggestion for those settings to be the DW default ? Maybe not ticking the min phase box obviously but the rest should be default?
