I like to share some findings regarding VB-HiFi-Cable.
(not off topic please continue reading
VB-HiFi-Cable is touted as a
lossless virtual audio cable for Windows. With it you can connect the Audio Output of a Windows App to the Audio Input of another Windows App. For example, one of its use cases might be recording audio data from an audio playback application into a recording application.
After discovering VB-HiFi-Cable, I wanted to test the promise of lossless transmission.
As recording application on windows, I use the
freeware Windows App CD-Wave-Editor. It allows 24/96 recording and also can split a recording in single (FLAC) tracks. I normally use this feature for digitizing LPs.
I used
Roon as playback application because I am familiar with it.
After the installation of VB-HiFi Cable I see and enabled it as an Audio Device in Roon:
In CD-Wave-Editor it looks like this:
I recorded a track and compared the original with the recorded one using DelataWave.
Result: NOT Bit Perfect!
This was disappointing as I expected Bit Perfect transfer by VB-HiFi-Cable. Looking at the Spectrum Output of DeltaWave I saw that the recording was cut off above approx. 20 kHz.
I tried Foobar as playback app with same result.
Instead of VB-HiFi-Cable I next tried S/PDIF output of my ADI-2 Pro as output, routing it to its S/PDIF input and recorded this. Result: BIT PERFECT!
Digging a bit deeper I finally found the settings of VB-HiFi-Cable. You have to open Systemcontrol/Sound. On the playback tab you see
HiFi Cable Input in the list of devices. Now select it and open its properties:
At the “Extended” tab you can select the default format. And guess what: It was set to 24Bit 44.1kHz by default! I changed this setting to 24/96.
Same thing I did at the recording Tab for the
HiFi-Cable Output.
Hoping I now will be Bit perfect I again recorded from Roon via HiFi-Cable and analyzed the result with it with DeltaWave.
Now the recording was BIT PERFECT!
So don't believe you get Bit Perfect with HiFi-Cable by default. You have to adjust its settings first!
Dear
@pkane, thank you for developing DeltaWave. It's a truly versatile tool that helped me test and ultimately utilize HiFi-Cable's Bit Perfect promise.
Best DrCWO
