- Joined
- Jun 5, 2020
- Messages
- 4,808
- Likes
- 3,749
Your ears are probably not lying. Here are the two plotted.
OK - looking at this is hugely helpful for me, it is the 3K-6K where I think I am noticing the most difference.
If you're willing to mod. Removing the grill. Inside the bore there is a foam. Take it out. I wanted more bass so I taped the side went.S12 definitely, but I'm not convinces it's 2x better. That's the "problem" with TCZ - they set such a high bar for such a low price, you're hard-pressed to find an IEM that's better, and that's priced proportionally (not 10x more expensive for 2x subjective gain).
I think for some people just not needing an EQ is going to be worth that extra $40. Although compared to TCZ (and to my own taste), a bass boost is required, but out of the box it's not really lacking. Just toned down. After a bit of a low shelf all the lowest notes are there with pleasant oomph and rumble.
Otherwise the tonal balance is, to me, perfect, and overall I did not find anything that TCZ does better, other than deep bass extension out of the box.
The only bad thing about S12 is the cable, and it's really bad, I had no idea a cable can make my ears hurt so much. Luckily, the TCZ cable fits perfectly and with it I barely even feel I have IEMs on.
All in all this is a reasonably popular model, judging by how often it comes up in various reviews and comparisons - not quite at the Hexa level, but popular. And I can confirm that it's well worth a recommendation (for below $100 - perhaps not for the sticker price of 130).
Having said that, there is one thing that left me unhappy about this purchase. A few reviewrs one (not one or two) point out S12 as the benchmark in "technicality", e. g. resolution/detail retrieval, and I'm not feeling that at all. It's definitely no worse than TCS, but I don't feel it's better either. If anyone else reading this has S12/S12 Pro - I'd be very interested in your opinion.
Can you guys comment on how well the Hexa takes to EQ?
Humbug!I don’t use EQ for IEMs.
The Fiio/Jade JD7 is a really satisfying and fun IEM, quite similar to the cheaper FD1. The Artti t10 Planar is very good too.Humbug!
It's either HEXA w/EQ or FiiO JD7 w/EQ. They each need it but in a different way.
Why these? I'm looking in this price range for IEMs that have potential with EQ, are comfortable, and look decent.
It looks like it just needs a tuck to the midbass. I hope it's comfortable to wear, too.The Fiio/Jade JD7 is a really satisfying and fun IEM
Humbug!
I am the opposite. Harman is unrefined; the treble carries too much energy making everything sound grating on the ears. My testing showed the slope beyond the 3kHz peak needs to come down much faster. Instead, it is much too broad. I don't think the Harman study actually tweaked this as much as they could have before collecting data.Sure, but Need to meet a person preference.
After my audio journey in 25 years, I kind of diverged from Harman a bit, toward smaller bump in bass and more midrange / upper midrange.
Harman curve is for average person.
For the record, Harman target is not an average. It is tonal balance "most" people prefer. And allowing for deviations in bass and treble, it is what almost everyone prefers when tested blind.> If you listen to Crinacle's explanation, he describes exactly what I'm hearing
That is the point, that many of us hear differently, my wife is very very treble sensitive, she told me many times that "high frequency is off" for many my speakers with bad spin and wild angled reflection from twitter, but I kind of been OK with that spin. We are different, it's why there is no ONE solution for all or ONE curve for all.
I'm not saying that there is no "average" / "reasonable" tunning for average consumer, there is one for sure. I'm saying if you start searching for what you like, you will end up in a different place then I. Which totally makes sense.
UPD: also I like different curves for different experiences, IEM one curve with midrange focused. The monitors is quite bass-heavy, my big boys R11 quite neutral with small bump in bass, etc. Different experiences what bring most pleasure to me (I bet some people tune everything to one curve, and it brings pleasure to them). The point is, we are different here.
You'd probably like Tacnchjim One DSP, it's very enjoyable in person.I am the opposite. Harman is unrefined; the treble carries too much energy making everything sound grating on the ears. My testing showed the slope beyond the 3kHz peak needs to come down much faster. Instead, it is much too broad. I don't think the Harman study actually tweaked this as much as they could have before collecting data.
My preference is much closer to the IEF Neutral target, ala Crinacle. I have Truthear Zeros equalized to remove all resonances. Later, they came out with the Reds that went in the same direction. If you listen to Crinacle's explanation, he describes exactly what I'm hearing. So that's the reason for these IEM choices.
To me it depends on the 3-4k levels. If they are as high as Harman IE I prefer some upper bass bleed to counter balance. Overall my favorite is signature is IEF 2020 + slightly modified Harman bass. I don't see much improvement from IEF 2023, a step back if anything.(..)I'm mostly ok with Harman IE 2019 up until 3 kHz(...)
