The face!! It's priceless!!
To this day X-Voce remains the ONLY center channel speaker offerred for sale by GR Research. Exact same design. People still own, use and buy it.A product made 16 years ago by a company that is now defunct, for a product nobody is going to own and cannot buy? What is the point? It's pretty obvious you're just trying to demean GR Research. I'll admit I am skeptical of his operation, but this "review" post reads like a clearly veiled attack at GR Research and AV123.
I feel for you, if you have not found any merit to this otherwise great and educational post and what follows.A product made 16 years ago by a company that is now defunct, for a product nobody is going to own and cannot buy? What is the point? It's pretty obvious you're just trying to demean GR Research. I'll admit I am skeptical of his operation, but this "review" post reads like a clearly veiled attack at GR Research and AV123.
If you go to Danny's videos and post any comments that challenges him, reference any real science or ask him to defend his products against damning measurements, he has a drone of army who will delete any negative comments.How Danny ended up with a group of rabid, pitchfork bearing parishioners is beyond me. Even when I was a total newb I could see right through this guy. My first interaction with him was after a mod I made of a Behringer speaker. My nearly free and easy to accomplish cabinet mods clearly improved the response in a measurable fashion, but he was trying to say they were useless and the real way to improve that speaker was to spend a lot of money on crossover parts and rounding over the woofer cutout. I suggested it was better to do the cheap and easy thing that would measurably improve the speakers first before doing things that had no evidence to support their efficacy and cost a lot of money. Seconds later the pitchforks and torches swarmed me. The mob was angry. It was easy to politely defend my position, but the hostility snowballed and they vanquished me. I wonder if they did the same to the guy who had problems with this terrible design? How did he get silenced? you know full well that Danny remembered that “con“versation.
Yup... Imagine the sound with banana plugs!Did it have tube connectors ?
If not that could explain the measurements.
Would have been even more curved, right?Yup... Imagine the sound with banana plugs!
Due to room modes measuring below ca 200Hz is not easy. Ideally you use a Klippel or an anechoic chamber which is indeed expensive. Or you do it outside but need to be careful which is elaborate and only possible when dry outside.Why would someone not measure below 200hz? It's not like it costs more money to measure a broader scope...
Air Traffic Control.Or designing explosive ordnance.
Knowing how Clio works, the measurements Danny makes will have captured enough data in the impulse response to give a response down to 20Hz. As we know he gates the impulse response so the MLS gives frequency data down to around 200Hz so that he can show a pseudo anechoic frequency response. The files saved are the full impulse and can be gated however you like to generate the frequency response.Why would someone not measure below 200hz? It's not like it costs more money to measure a broader scope...
To me Danny comes across as Ray Samuels of good old Head-Fi days
For his upgrade videos it seems fair to focus on the gated frequency response as this is the area of concern, I.e. the crossover regions. Although occasionally he will modify a port to minimise a resonance so it would be nice to see some frequency response measurements with the mic placed very close, just to back up any improvements shown in the impedance curve.
For his own designs though I’m not sure why Danny doesn’t come up with at least a reasonably repeatable and consistent method for measuring the LF drivers close up (say ~1cm) and then splicing that response with pseudo anechoic response. It’s old school and flawed but at least you can qualify your measurements as such and give people some idea of what’s going on below 200Hz.
Or even just find the least bad position in his premises to measure the speaker where he accepts a certain amount of room reflection into the low frequencies by using a longer time duration for the gate. Again, you qualify your measurements as such and at least if all your measurements are made under the exact same conditions then relative comparisons can be made between different speakers even if the absolute accuracy is low compared to true anechoic or NFS.
Yes I think so for low bass, although I think it’s preferable to have the speaker in free space to measure the baffle step accurately. The ground reflection will be far too short in time to get accurate mid and high frequencies. A platform about 3m high is probably far enough away from a boundary (the ground) to get some accurate data down to 50-60Hz.Some low-frequency speaker measurements are made out in the open air, i.e. away from any walls objects that could acoustically interfere. For example, this sub measurement by AH. Is such a ground-plane evaluation a valid approach?
