shrimp_dude
- Joined
- Mar 12, 2020
- Messages
- 80
- Likes
- 69
Just amazing, it really is
But it has all the prerequisites for an Audiophile piece of equipment.....Heavy, Expensive, Blue Light and a cult-following at Head-Fi.
Even with all the poor measurements, it must sound fantastic
Still many people will keep liking those r2r dacs,citing some magical property which make them "sound good" despite poor measurements.
I have owned a few audio-Gd products, in fact I sent Amirm a DAC and a DAC/amp to test, and the results were miserable. Their build quality is kind of over-the-top which I thought would result in good sound. It does not.
By the way, there is such a thing as a "Class A voltage regulator" but it is usually not named that way; the more common electrical engineering term is SHUNT REGULATOR. They offer low source impedance, good regulation and make lots of heat.
Audio-Gd pays a lot of attention to power supplies. Their power supplies are quite good. Unfortunately, the rest of the circuitry and firmware leaves much to be desired as we can see from Amirm's analysis.
As I have said before, I would like to see a blind listening test to see how readily we can hear the difference between something like one of these "broken" designs and a decent design like the various nice Topping DACs. I think we would be surprised at the results of such a study. While it is my belief that some people could hear the difference, I don't think many of us audio hobbyists are nearly as good at hearing as we like to think.
This DAC is typical of Audio-Gd products, it seems to me. People buy their gear and report being happy with it. Surely if typical users were able to readily hear the flaws in these products, they wouldn't sell very many. But Audio-Gd enjoys fairly robust sales- and this makes me think that many people can't hear these flaws.
Exactly, most people hear what others wanted them to hear. This audiophile hobby has been driven by mostly subjective opinions over the last many years. Many big brands deliberately plant goody goody subjective reviews through so called reputed review forums. These reviews mostly are nothing more than permutations and combinations of few audiophile jargon words. But since past few years asr has shifted this towards more of an objective approach. Many people like us eagerly wait for asr reviews. Many brands have even changed their approach of designing the products based on these asr reviews, schiit being one of them. But I still think there is long way to go. More and more products you send to asr for measurements, better will be the chances of design improvement in future products.I have owned a few audio-Gd products, in fact I sent Amirm a DAC and a DAC/amp to test, and the results were miserable. Their build quality is kind of over-the-top which I thought would result in good sound. It does not.
@amirm needs a panther that is just a pile of broken, pink ceramic shards to classify devices that are overly-engineered with such stunningly poor performance. The headless panther just doesn't cut it in a case like this.
One has to wonder about what’s in the head of the designer of this crap when he draws schematics.
Well actually I bet it’s more simple…When his calender of the whole year marks April 1st, such schematics were being drawn.....
This is a review and detailed measurements of the Audio-gd Master 7 Singularity DAC. It is on kind loan from a member. Can't quite find the cost for it but seems to have sold for $2,500 or so when it came out in 2018 (?).
I must say, this is one of the heavies DACs I have measured:
If you are paying for weight, you are certainly getting your money's worth! I was surprised that there is no volume control on the unit. The only control is to select one of 6 different inputs:
I get a kick out of the tape (upper left) that is supposed to tell them if you opened the unit because to change its settings, you have to change jumpers inside!!! Speaking of inside, here is a shot of it:
There no jumpers set in there but I can't figure out from their "manual" what that means. The English is quite poor. Owner had not modified it and I tested it as is. Company says after "May 15" settings are one way versus before. Problem is, it doesn't say which year!
Speaking of the manual, it starts this way:
Unbelievable.
Man, this DAC was an adventure to measure. I started with USB input whose jack is kind of crooked in the back. The clock in the dashboard was jumping back and forth every few seconds so I plotted the frequency by itself and got this:
So every two seconds or so, it jumps precisely from 1 kHz to 0.9993 kHz! Clearly there is a bug in the clock locking algorithm here. Fortunately it doesn't happen with the other two inputs (Toslink and Coax) which I tested. Because of the disturbance, I could not filter the FFT for USB so it looks more fuzzy than it would be otherwise:
Nominal output is around 5.3 volts or so. To make the comparison more fair I brought that back down to level you see with -2 dB attenuation on the input (it doesn't change the results hardly at all). We see that there are some 8 dB difference in distortion between one and the other channel. Averaging the two SINADs we get 85 dB which puts the Master 7 squarely in the poor category of all DACs tested:
Zooming in you can see its competitors better:
Two notches higher is the Google phone dongle!
Back to our dashboard, this is what you get when you switch to Coax and Toslink:
So much garbage and variability.
Moving on to dynamic range we get another poor result although not as bad as distortion:
I went testing IMD and for kicks, I also measured RCA out in addition to balanced which was used above:
The balanced output is not much better than a phone dongle but what on earth is going on with RCA out in green? So I went back and ran the dashboard with RCA Out:
What on earth are you doing here Audio-gd? Why produce so much more distortion with RCA as opposed to balanced?
Jitter test shows distinct difference between USB and coax+toslink:
So much for fancy PLL implemented in FPGA and such.
Considering what we have seen so far, Multitone results were much more decent:
Since the output is higher than 4 volts, let's sweep it to find the sweet spot:
Oh come on now, what is with that ditch at 1.5 volt? This curve should smoothly climb up and then maybe drop a little. It should never have this kind of nonlinearity.
Speaking of non-linearity, let's run our linearity test:
Notice how the level shifts as you get to some amplitude with a constant error. There is some kind of design problem here.
Filter in the output stage is quite slow (and hence wrong):
This is partially responsible for poor response in our THD+N versus frequency which uses wideband measurements:
The total noise and distortion literally jumps out of the chart above 500 Hz! Switching to 192 kHz sampling eliminated the effect of the slow filter (green and brown). Sadly performance is still quite poor and gets worse with frequency above 1 kHz. In that regard, our dashboard which also runs at 1 kHz is showing the best case response, not the worst.
Some of the earliest DACs I tested were from Audio-gd. Results were not only poor but different than what company advertised. This DAC was kind sent to me to see if their newer products do better. Sadly they do not. The Master 7 Singularity has a suite of problems in many areas. Clearly it has not benefited from proper design verification and optimization. Tons of parts are thrown at the problem which look good on paper and website but perform very poorly. Performance is simply unacceptable at any price let alone what they charge.
Needless to say, I cannot recommend the Audio-gd Master 7 Singularity.
