Like I said, compare what? Using a subwoofer and room correction to not using a sub/room correction?To try and compare. I use Primare universal player and analogue connection.
I'm not sure that's correct. The manual states that analog audio can be passed through with no processing at all (including A->D). You can turn off ARC and bass management on inputs, so I'm not sure pure DSD is automatically converted. Could you point out where in the manual this is stated?The AVM 70 converts DSD to PCM anyway, so the DSP is not bypassed. Room correction, bass management, tone controls etc are still working with native DSD input.
Manual, what's that ???The manual leaves no clues here sadly.
EDIT: in fact, it appears from users on AVS that the AVM 70 can play DSD files unconverted if you decide to forego any processing.
In you previous post you said it was native. You are correct there, why change your mind now and confuse the issue? To decode DSD natively, you do need to use digital input, and your players need to be be set to output "bitstream". The "convert analog" is an option available when you are using analog input so it does not apply to DSD native, that is applicable only if you use digital inputs.The manual leaves no clues here sadly. However, the “convert analog” option that bypasses all DSP is only available on analog inputs. With any digital input, including HDMI, it is not available. For this reason I doubt that it can do DSD native. Anyway, it does not matter at all.
It should be -3 dB.How should AVRs in general handle the level of the center channel signal in a speaker setup without a center channel speaker, like with a 4.1 setup? I’ve found that my AVM70 just sends the center input to both front L and R speakers without any attenuation, resulting in the center channel signal being 3dB too loud. I’ve found no way do adjust it either….
Interesting, but are you sure that's how it does that, and how would you know that for sure, by measurements, Anthem website info, or told by Anthem support?How should AVRs in general handle the level of the center channel signal in a speaker setup without a center channel speaker, like with a 4.1 setup? I’ve found that my AVM70 just sends the center input to both front L and R speakers without any attenuation, resulting in the center channel signal being 3dB too loud. I’ve found no way do adjust it either….
Measurements using REW. Laptop connected with HDMI to the AVM70.Interesting, but are you sure that's how it does that, and how would you know that for sure, by measurements, Anthem website info, or told by Anthem support?
That's disappointing. What did they say?I’ve only tested it with PCM input so far, which does this wrong
I contacted Anthem support about it, and received nothing but nonsense.
Almost like they didn’t understand the question.This is what they said…. Makes no sense at all.
Naturally, in the absence of a center speaker, the audio content intended for the center will be redirected to the front left and right speakers, resulting in these channels being louder. Additionally, front speakers typically have greater output capabilities than other channels. Anthem Room Correction addresses and resolves this issue.
I think they did, if you play contents that has the center channel, but you are relying on the phantom center effect, that's how the AVM works, according to their explanation. We may not like their response, but I think they are just giving us a honest anwer.Almost like they didn’t understand the question.
This is an unfortunate bug.
