- Thread Starter
- #61
A new champion has topped the list: the Soulution 710 amplifier (discontinued), as measured by Stereo magazine, which I only have the yearbook edition of 01-2008. Yes, it was not so great in the Stereophile measurements though.
Well, there is so much a single number can do to summarize the 4 dimensions of measured performance (power x THD+N x signal frequency x output impedance).I always feel like there needs to be a different measurement than distortion at some selected power (e.g @ 5W), and instead is an aggregate over the entire power band before clipping or something. Because, for instance, the Icepower modules perform on-par with many other respectable amps for the first chunk of the power band, but then start to fall apart comparatively beyond 5W. I suppose being sub-0.01% at 20W into 4 Ohms isn't terrible, but it's also not SINAD of 94 either. It's more like a SINAD of 80.
Ok I have migrated the data to a Google spreadsheet, let me know what you think.
227 amps now, phew!
I thought about it but these are not complete amplifiers, only parts. The Purifi had EVAL-1 tested and listed, but NC400 DIY kit is missing indeed. If I am to include ASR measurements into the list then it will be there with Amir's measurements. Along with some NC1200, NC2k and NC500 based amps.Any chance of adding amplifier module?
Ex. Purifi 1ET400A, Ncore NC400, etc
I wish to search/sort by specific model.
@amirm is this ok to you? All ASR entries linked to the original review post?I am thinking on adding ASR's measurements to this list in order to have the full picture in 1 unified list. My idea when building this current list was to complement ASR's list, but keeping both separate was not my goal in itself.
What do you think?
Sadly I need to remove all entries from Stereo magazine as they measure THD and not THD+N, so their numbers are not comparable. I am replacing the ones I find with measurements from other sources, but many amps are leaving the list. Down to 230 amps now.
And Benchmark AHB2 is back on top of the rankings where it belongs.
Probably, I don't recall all of the removed amps. And its SINAD was not comparable before if it was THD only, so unfortunately we have to forget about it.By chance is this why the Cambridge 851W is gone now, or was it never there and I just imagined it? Only decent set of specs is from an AU mag, but they ran all tests combined with the 851E which is unfortunate
Maybe you can email Cambridge and ask them for the power x THD+N graph in 4 ohms? Some manufacturers have these already and are willing to share. Although others simply ignored when I asked...
