Thanks! Man none of them do well do they....!Done!
I couldn't find the test of the V2, but the difference may be down to using an analogue input instead of a digital input.Anyone have any thoughts on why the NAD M10 V2 has such a low Sinad (74) and the original M10 is listed as 86. I’m not sure if they use the same nCore module but they both use Sabre DACs. I would have expected a higher Sinad with any nCore.
This is probably it. Amir saw wild swings in the noise floor using the analog input so he switched to coax. The M10 V2 data was taken from a Soundstage! review and they used the analog input. ThanksI couldn't find the test of the V2, but the difference may be down to using an analogue input instead of a digital input.
Done, thanks for pointing it out.Just stumbled across your list, great work! Can we get the Aiyima a07 max added? https://www.audiosciencereview.com/forum/index.php?threads/aiyima-a07-max-amplifier-review.49920/
Perhaps a tiny tiny correction - maybe it is not a "mistake" but just "imperfection":Let me know if you find any mistake.
And I thought, I was the hugest Spinorama.org fan!!!Hi totti1965, you are right and I have opened the B100 in its 3 gain levels.
I wonder if I should remove the entries with gain < 20, which are practically unusable in normal hi-fi systems, as they need tons of voltage from the source, something that only pro-audio interfaces and AP signal generators can actually achieve. But I have not decided yet and kept them in there so far.
Edit: awesome is @pierre 's Spinorama.org which I am a fan, that is "real work", mine is just a simple spreadsheet with a few formulas and graphs.![]()
