Amplifier SINAD list ASR + 3rd parties
Eetu
Helsinki
Really a huge job! Thank you!
I wonder how much the sinad of this 3 amplifiers is, they all get great reviews:
Audiolab 6000A
Marantz PM8006
Yamaha A-S801
The Marantz PM8006 seems to have a SINAD of 62dB (~0.08%). Not sure why it's not on the list.
Source: https://audio.com.pl/testy/stereo/wzmacniacze-stereo/2911-marantz-pm8006#laboratory
If Audiolab 6000A is the same as 6000A Play then it's already on the list with a SINAD of 69.
Edit: Oh and the Yamaha A-S801 is SINAD 61
daniboun
France (Lyon)
For your info
Matias
Matias
São Paulo, Brazil
Audiolab 6000A
Marantz PM8006
Yamaha A-S801
Done.
For your info
Same SINAD as L7 so I will keep Wolf's as he came first. :)
I am no expert in the Audiolab line but I think they are different units, added both.
Caciara
I admit I’m just a newbie so I’m still trying to figure out how amplifiers are tested but I’m surprised by the Yamaha A-S 801, seeing the audioholics tests I thought it was much better. Probably is my ignorance and they were tested differently by audio.pl and audioholics
Yamaha A-S801 Audioholics
Matias
Matias
São Paulo, Brazil
This is known, as I wrote several times now, I keep the highest measure in the table.
Let me know if you find an error though and I will fix it.
Matias
Matias
São Paulo, Brazil
ENG
Copenhagen, DK
Hello Matias
are there data enough to put
this amplifier (C 399) in your informative
Amplifier list ASR
Greetings Eng
Vollverstärker​
NAD C 399​
Fulminant ausgestatteter und ganz exzellent klingender Vollverstärker mit eingebauter (modularer) Zukunftssicherheit. Hohe Leistung, ESS Sabre-DAC und optionales Streamer-Modul mit Raumkorrektur und Smart Home-Funktionen. Sagenhaft.
Preis: ab 2000 € (Stand: 07.01.2022)
Maße BxHxT: 43,5 x 12,2 x 41 cm
Gewicht: 11,300 kg
Garantie: 2 Jahre Garantie (3 Jahre bei Registrierung)
Hersteller: NAD Electronics International
Netzphase am Gerät
Allgemeine Daten​
Ausstattung​
Fernbedienung, High Res-DAC, Phono-MM mit innovativem Subsonicfilter, HDMI, Klangregelung, MDC2-Modultechnologie für Nachrüstungen (BluOS-D für Streamer/Smarthome/Raumkorrektur), weitere Module in Planung.
Messergebnisse​
Messwerte​
Dauerleistung an 8 Ohm (1kHz):216 W
Dauerleistung an 4 Ohm (1kHz):256 W
Impulsleistung an 4 Ohm (1kHz):269 W
Klirrfaktor bei 50mW (1kHz):0.09 %
Klirrfaktor bei 5W (1kHz):0.003 %
Intermodulation bei 50mW (nach DIN):0.0047 %
Intermodulation bei 5W (nach DIN):0.0011 %
Rauschabstand ab Hochpegeleingang bei 50mW (1kHz):73 dB
Rauschabstand ab Hochpegeleingang bei 5W (1kHz):– dB
Rauschabstand Phono MM (5 mV / 1 k) bei 5 Watt:66 dB(A)
Dämpfungsfaktor an 4 Ohm bei 63Hz/1kHz/14kHz:165/159/80
Gleichlauffehler Lautstärkesteller bei -60dB:0.1 dB
Leistungsaufnahme Standby:26.5 W
Hohe Ausgangsleistung, in der Praxis exzellente Verzerrungs- und Rauschwerte, guter Dämpfungsfaktor und prima Lautstärkegleichlauf, insgesamt sehr gute Übertragungswerte.
Matias
Matias
São Paulo, Brazil
@ENG hi unfortunately not, klirrfaktor is only distortion and not distortion+noise THD+N.
Reactions: ENG
Matias
Matias
São Paulo, Brazil
Can you please add the Topping LA90 in bridged mono mode to the list?
Thank you
Nice, thanks for pointing out. I read about 120 dB SINAD in 5W and 180W at 1% THD+N. I assume it was with volume bypassed.
Matias
Matias
São Paulo, Brazil
Matias
Matias
São Paulo, Brazil
daniboun
France (Lyon)
You can now add the Soncoz SGP1 !
