Where should I start...?Lol, and why would you take the Topping over the Aiyima?
IMO there needs to be a no-PSU purchase option. Many veteran "chip amp" users already own suitable PSUs.A70 has started pre-sale, and you can get a 10% discount for pre-sale.
AIYIMA A70
AIYIMA's latest TPA3255 power amplifier has PFFB function and is equipped with 48v5a GAN power supply. Parameter:Chipset: TPA3255+NE5532Replaceable operational amplifier chips: RT3609SM, OPA2604, OPA2134, LM4562, JRC5532, OP275GSZ, OPA1612, MUSES01/02/03...www.aiyima.com
I understand the logic and agree. Even if the 5a power supply had better numbers, I’d have no interest in buying it. There’s plenty of other amps offering a smaller power supply with similar features using that chip. To me, the point of the A70 is more features AND much more power.I gave the answer. It makes little sense to get the half power supply just to save $30.
At that price I’d bet you’re stuck with buying one with a 5a supply and replacing it. Maybe you can find one on a Chinese website.IMO there needs to be a no-PSU purchase option. Many veteran "chip amp" users already own suitable PSUs.
Personally, I’d like to get my hands on just the 10a power supply
Good call, I’ll keep an eye out on their website.I wonder what they will go for on the Aiyima site when they do start selling it on their power supply page. My guess is $65.99 as it carries a $30 premium when purchased with the amp over the 48v/5A PSU, which now sells separately for $35.99.
In what world would this term a problem? Sorry but that sounds a little bit like woke BS to me. The term Chi-Fi is used across all of the internet regarding Chinese hifi products. Some people just try to get offended by everything.
OMG. Thank you! What a fine education you can get at ASR. It's really amazing and gratifying. I understand almost all of what you wrote. Only a couple of points...TL;DR version:
It is a limitation of Amir's reactive load box, and it prevents the reactive load testing on some amplifiers due to the design of these amplifiers. This limitation is not relevant to the vast majority (99%+) of passive loudspeakers, which are what these amplifiers intended to drive.
More detailed version (will need some basic understanding of electrical circuits):
The TI class-D amplifier chip that does the majority of the work in this amplifier can operate in 3 different modes:
The TI TPA 3255 chip used by the A70 has 4 amplifier sections. It can drive 4 speakers in its SE (single-ended) mode; 2 speakers in its BTL (bridge-tied load) mode, or simply bridged mode; and 1 speaker in its PBTL (parallel bridge-tied load) mode. The A70 is configured to operate in the BTL mode.
In the SE mode, one side of the speaker (usually the negative terminal), is connected to electrical ground inside the amplifier. In the BTL mode, Output B is configured to have its output at the reversed polarity of Output A (similar for outputs C & D). The combined output of OUT A and OUT B doubles the voltage output to the speaker. By "bridging" together outputs A & B, the amplifier can double its output voltage capacity without having to increase the power supply voltage as in the SE mode (i.e. use the same power supply). The output current limit of the BTL mode remains the same as SE mode, and since 2 amplifier sections are together driving the speaker, the "apparent load impedance as seen" by each amplifier section is half that of the speaker. That's why for bridged amplifiers, the rated minimum speaker impedance is usually twice that when they operate in the single ended mode.
To counter the output current limitation, in the PBTL mode the amplifier is configured to 2 BTL sections in parallel (each providing half the demanded output current), thereby doubling the current output capacity. The minimum required speaker impedance in the PBTL mode is the same as in the SE mode, but with output power is increased by ~4X.
The issue with Amir's complex load is that it expects the negative output of the amplifier to be connected to the electrical ground. Since this is not the case with the BTL or PBTL modes, the complex load box doesn't work all the time for bridged amplifiers. This is not a problem with the vast majority of passive speakers as they don't need nor expect the negative amplifier output to be at electrical ground. Exceptions may include some electrostatic speakers and the older Polk SDA (don't know about the current ones).
How does that happen? I would imagine a load box to be a network of high power resistors, capacitors and inductors. Why would that expect something?The issue with Amir's complex load is that it expects the negative output of the amplifier to be connected to the electrical ground.
So what about solid, sincere or even emphasized hi-fi? And how comes, that here it is not China which comes into customers’ minds immediately?
I know what GaN semiconductors are and i have used them multiple times.GaN semiconductors, e.g. diodes and transistors, are significantly more efficient. This allows smaller, cooler and more powerful switching power supplies to be built, but above all more efficient ones. This can improve the efficiency by 5-10%, which would also be the measurable difference.
Information about gallium nitride / GaN semiconductors can be found online.
GaN has become a blanket marketing buzzword.
They are not "more efficient" but if done right they can be used to make Smaller converters or more efficient ones
So why should the user care how they get the efficiency and power density. and how would you test this?
what matters is that the whole system performs to spec
This one doesn’t look very large, particularly for a 10a. I can’t find any similar brick power supply, they’re all 48v 5a. That in itself is an innovation for this product.A 480W SMPS brick sitting on shag rug under the sofa that doesn't catch fire and burn your house down is kinda important.
These outboard supplies are getting ridiculous- look at the "amplifier" and its power supply- it's stupid looking if you ask me.
It would look like 4 to 6 power bricks attached to a small box.With this kind of performance, it will be interesting to see what a 8,11, or 16 channel multichannel amplifier could look like, using TI Class D chips and a integrated power supply, sort of like a modern Lexicon DD8.
On the other hand 4 x 220 = $880 at which point the NC252MP seems to be a better deal at “just” 2x the price.
