I observed Mains and Noise Floor variations 'relative' to power sources and /or other interferences. Isolated , until about 70% volume (2 o'clock pos.), It seems to do just what it's meant to. Clean input = Clean Output. Noisy input = Noisy (amplified Output). 20khz roll-off seems negotiable from an end user listening standpoint (hopefully!). 2.1 makes sense purely with a dedicated Active-sub. Also, volume control won't work!! Limitations? Sure. Worth it? So far .. yes.- high noise floor
- high mains hum residuals
- high order distortion components in the spectrum
- low BW with roll off at 20kHz
Why is this recommended? Because it is small and Class D? Are there any specifications limits for recommended components? And why not?
Click/ pop : only if the amp is switched on first (before the source). But that's standard for many Great ones too. Not all have a soft-start at this pri. Point!
This amp is a great addition to an Audiophile ensemble, or a great 'starting' point for a sprouting enthusiast. Hope it has a reasonable durability.
Slightly curious with the heat dissipation part. But a few fans seem to help!!
Question: Anyone tried a 3 or 2 ohm load? Also , what's a 4*se config? Thanks folks!! Hope it helps some qs!!
