Guddu
- Joined
- Feb 10, 2020
- Messages
- 890
- Likes
- 792
It appears like the new Aiyima A07 MAX has made out to AliExpress: https://www.aliexpress.us/item/3256805898598328.html?gatewayAdapt=glo2usa4itemAdapt
It looks nicely build with quality components with additional feature than others.
- It has vent holes at the bottom plate for cooling. No vents on the top which probably makes more sense.
- They are showing quality components
- For me, Star of the show is Mono/Stereo selectable option
* Full internal PCB pictures aren't available yet.
It's available on AliExpress at the momentonly, not on Aiyima US store or Amazon US yet.
Currently available for:
Approx. 62$, after discounts, amp only
Approx. 85$, after current discounts, with 36v PSU
Approx. 91$, after current discounts, with 48v PSU
From AliExpress:
Specs:
Stereo Max Output Power(switch stereo mode):300Wx2 / 4Ω(48V/12A)
Mono Max Output Power(switch mono mode):600W/ 2Ω(48V/12A)
(R+ connect to speaker +, L+ connect to speaker -)
Working Voltage:DC24-48V,5A or more
Replaceable Op-Amp Chips:OPA2604AP, OPA2134, MUSEO1/02/03, LME49720NA, LM4562, AD827AQ, etc
AUX OUT: active subwoofer or power amplifier
3.5mm AUX OUT as output connect to next amplifier without volume control >>>> So, no volume control to AUX/Pre out
THD:0.007%
SNR:≥110dB
Input sensitivity:1V >>>> Should it not be around 2V?
AUX Maximum Output level:1V >>>> Should it not be around 2V?
From AliExpress:
Specs:
THD:0.007%
SNR:≥110dB
