How about reading the posts before yours before asking?
The posts before mine were referring to modifying the Zero 2. I am asking about anyone who has experience with the Chu 2 or Wan’er to see if they had better luck with nozzle length.How about reading the posts before yours before asking?
Zero 2 - Nozzle too short
Not all of them. It's a long thread. I suggest you read it through.The posts before mine were referring to modifying the Zero 2. I am asking about anyone who has experience with the Chu 2 or Wan’er to see if they had better luck with nozzle length.
I did a search on Chu 2 and Wan'er in this post and found nothing relevant to my questions. No posts on the Wan'er and just one on the Chu 2 that referenced tips. I tried.Not all of them. It's a long thread. I suggest you read it through.
Awesome, thanks! I appreciate the option. They do look like nice tips. I am trying the tips I got with my Reds… they are working better. Not quite there yet though. Thanks!I have a similar issue with the new Kiwi Ears Singolo and ordered These Dunu S&S ear tips, longer and wider to the end of tip than the usual “bud” style so I should get a decent seal, ordered in large and xl.
I had this problem, and I was finally able to get a good seal, and deeper fit, with the AZLA Origin tips, as they have a longer stem to compensate for the short nozzle of the Zero:2. No other tip I tried, including the Dunu S&S worked for me.Awesome, thanks! I appreciate the option. They do look like nice tips. I am trying the tips I got with my Reds… they are working better. Not quite there yet though. Thanks!
AZLA Origin tips
When said IEM is released/discovered for no more than $20 extraThose tips are $20, apparently.
At what point it is better to just buy a competently designed IEM?
Hey I was the one who mentioned the Chu 2I did a search on Chu 2 and Wan'er in this post and found nothing relevant to my questions. No posts on the Wan'er and just one on the Chu 2 that referenced tips. I tried.It is along thread I have been following for several months.
For $46 you can get a discounted Truthear Red right now https://shenzhenaudio.com/products/...ero-red-dual-dynamic-drivers-in-ear-headphoneWhen said IEM is released/discovered for no more than $20 extra![]()
Well, I already own the Zero:2, and I am past the return window. I also really enjoy them now with the new tips, and I have paid far more, in the past, for IEMs that I don’t like the sound of nearly as much. In addition, the thing with good ear tips like those, is that I can use them with other IEMs that I own, as well.Those tips are $20, apparently.
It was you! Thanks for chiming in. I’ve been doing a bunch of tip swapping and the largest set that came with the Zero 2 (pale yellow) is where I am at. I like the sound of the Zero 2. Chu was my next option, but I’ll see if I can avoid the tip shredder! Yikes!Hey I was the one who mentioned the Chu 2Chu 2 has more desirable nozzle length for sure, but it shreds some of my ear tips as you might have read and I still prefer the Zero 2 with regards to sound
Interesting take as I heard some other members preferring longer tips for the Zero 2I am using Moondrop spring tips, fit perfectly in my ears and very soft outer which seals well and doesn’t cause any discomfort, quite shallow fitting which aids the bass response, you can feel a very solid in-head thump if you carried away with volume.
I’ve tried comply foam which inserted too deep affecting the bass response, tried a few Azla spinfits which I’m not too impressed with,
Currently got a few tips coming from aliexpress such as the Divinus Velvet , Tangzu Tang Sacai Balanced , Tangzu Tang Sacai Wide Bore , and of course I had to get more Moondrop Spring Tips
I have a Symphonium Meteor iem arriving this week and I want to make sure I have a nice choice of tips to get a good seal and fit/comfort.
Short nozzle iem’s such as the Zero 2, and my new Symphonium meteor benefit audibly from an ear tip that doesn’t insert too deep into the ear canal and I prefer wider bore tips as I feel they allow the iem to deliver sound as it was designed.
If I was you I’d get a set of moondrop spring tips, measure the width of your current favourite/best fitting tip and order the appropriate size.
