If I don't hear a difference sighted, doing a DBT is ridiculous. And you know that.You are doing controlled double blind tests vs. SOTA solid state amplifiers to support your claim?
This particular amp is a poor design. To broadly put all tube amps in the same category is not accurate. The real question is : what level of distortion can the average individual detect? A THD of -120 db seems rather low and may be deep into "it just doesn't matter" territory. A properly designed tube amp matched to a sufficiently flat impedance speaker may not be distinguishable from a solid state amp in blind tests.If it is only a function of topology, then please show me a tube power amp with THD of -120dB at 1kHz/4ohm/100W. You know very well that tubes cannot reach parameters of the SOTA solid state amplifiers, because the same topology cannot be used for them and because of their limited output current that asks for use of the output transformer. And, a complementary tube pair would need new discoveries in the field of physics.
"Any proof?"
What kind of controls?
Or just an anecdotal statement?
You may be biased by your attraction to tubes thus not hearing a difference in the sighted testIf I don't hear a difference sighted, doing a DBT is ridiculous. And you know that.
The photos are a bad example for me as the original looks bad and the added noise doesn't improve it.It's not to mask, but to enhance good equipment and material.
thus not universal. I do not understand why you guys protect the tubes. There is no single advantage of using them for audio in the 21th century.matched to a sufficiently flat impedance speaker
There's no reason to add salt and sugar in our food either, but some claim that food or coffee tastes better.thus not universal. I do not understand why you guys protect the tubes. There is no single advantage of using them for audio in the 21th century.
www.stevehuffphoto.com
You mean a fixed amount of salt and sugar for everything?There's no reason to add salt and sugar in our food either, but some claim that food or coffee tastes better.
HiFi: The Willsenton R8 Integrated Tube Amplifier is a NO BRAINER BUY. | Steve Huff Hi-Fi and Photo
HiFi: The Willsenton R8 Integrated Tube Amplifier is a NO BRAINER BUY. By Steve Huff This may be the biggest no brainer purchase in the history of HiFi high quality audio integrated amplifiers. Seriously. There has been much praise and press online and on YouTube about this amplifier, and as I...www.stevehuffphoto.com
It's not about protecting tubes. One may prefer tube amps for various reasons. Such as : ease of repair, not affected by static discharge, aesthetics, etc.thus not universal. I do not understand why you guys protect the tubes. There is no single advantage of using them for audio in the 21th century.
Just like the top performing range, the bottom end has a mix of ultra cheap amps (using outdated chips) and some very expensive brands. That lowest rated carver amp is a pretty penny I think. But hey, at least Carver, like Nelson pass, is upfront that many of his sons are intentionally designed to be distortion machines, ie, alter the sound in ways you may or may not like. I mean this is the guy who also made “sonic holography” preamps that DO create an unreal exaggerated spatial sensation (sort of like apples Spatial Audio) for one person sitting within a 6” spot. And made his name by showing how he can “voice””his amp to sound like another brands amp Reproducing the recorded sound accurately is not always his goal.The good point though: Here’s an opportunity to take a close look at the bottom end of the SINAD scale finally
That is not how perceptive biases work. They are not like prejudices - it is not that meaning of the word "bias"You may be biased by your attraction to tubes thus not hearing a difference in the sighted test.
Distortion order that dominates is (primarily) a function of topology; the absolute level is dependent on other things.If it is only a function of topology, then please show me a tube power amp with THD of -120dB at 1kHz/4ohm/100W. You know very well that tubes cannot reach parameters of the SOTA solid state amplifiers, because the same topology cannot be used for them and because of their limited output current that asks for use of the output transformer. And, a complementary tube pair would need new discoveries in the field of physics.
I think the whole chain of events ends at our brain. What do we find most enjoyable.Not everyone actually is looking for high fidelity as the words are defined by Webster.
How many though, are looking for low fidelity? At least, how many would admit to it?Not everyone actually is looking for high fidelity as the words are defined by Webster.
Do you add sugar to your coffee or do you drink it naturally black?You mean a fixed amount of salt and sugar for everything?
Depends on my mood. Sometimes I like it black, sometimes I like it with some half-and-half, sometimes I like more sugar, sometimes I like none. If I am going to adulterate it, I want to do it with the amount of my choosing, at the moment. Not fixed for me by someone else whose taste probably has not much correlation with mine.Do you add sugar to your coffee or do you drink it naturally black?
That’s exactly the right word. Culinary arts are a form of adulteration of nature’s flavors. Not everything that is grown or raised in nature tastes good as it is. Most of it does not. Music is different: the instruments of the orchestra and the newer electronic instrument are inspired by Nature and its sounds and noises: the wind as it caresses the trees, the ice melting of an Alpine lake, birds songs, the rumble of an avalanche, the thunder and the rain, might have inspired the designers of the first musical instruments over a multi-millennia path of trial and error research, along with the evolution of theory from Pythagoras onward. No need to add flavor or adulterate musical instruments. I moved from a high distortion system of my first Philips cassette player in 1972 to the lesser distortion of a PAS-3x/ST-35, better and better speakers, solid state amplification, class D and SOA DACs, and never went back.Depends on my mood. Sometimes I like it black, sometimes I like it with some half-and-half, sometimes I like more sugar, sometimes I like none. If I am going to adulterate it, I want to do it with the amount of my choosing, at the moment. Not fixed for me by someone else whose taste probably has not much correlation with mine.
Can both camps agree that this amp is not bad because it's a tube amp
About 1% (-40 dB) for untrained listeners.The real question is : what level of distortion can the average individual detect?
How much distortion or noise do you think the mastering engineer wants you to add?Perhaps not in the way you intended, but that second sentence is a perfect follow-up to the first.
