Yaqin MC-84L Tube Stereo Amplifier Review
Rate this amplifier:
    Votes: 243 93.5%
    Votes: 5 1.9%
    Votes: 3 1.2%
    Votes: 9 3.5%
This is a review and detailed measurements of the Yaqin MC-84L Stereo Tube amplifier. It is on kind loan from a member and costs US $600 on Amazon.
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Valve review.jpg
The picture doesn't do justice to the nice design of this amplifier. The transformer case in the back nicely contrasts with the chrome parts. The latter does make the labels hard to read though when looking from above:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Valve back panel review.jpg
One set of binding posts is available for 4 ohm and the other, 8 ohm. Seeing how speakers don't have constant impedance, nor are advertised correctly as such, I feel bad for people trying to figure out which posts to use (common criticism for all such amplifiers). Let's see how it performs.
There is a headphone jack in the back which I did not test.
Yaqin MC-84L Stereo Tube Amplifier Measurements
For all but 8 ohm power test, I used the 4 ohm tap. Let's start with our dashboard:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Measurement.png
We have the high harmonic distortion which we kind of expect. But a lot of mains noise comes along for the ride, causing intermodulation with our main 1 kHz, making for a mess. SINAD which is the sum of all unwanted "stuff," lands the amplifier at the bottom of our rankings:
Noise is a step above but still nothing remotely to be proud of:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier SNR Measurement.png
Frequency response is flat enough if we ignore varying performance between channels:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Frequency Response Measurement.png
Crosstalk is one step above mediocre:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Crosstalk Measurement.png
You get a better feel for distortion when we use 32 tones to simulate "music:"
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Multitone Measurement.png
Not pretty. Same story for 19+20 kHz tones:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier 19 20 kHz Measurement.png
The amplifier is fairly rated at 12 watts, assuming you don't care about distortion:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Power into 4 ohm Measurement.png
One channel is having trouble above 2 watts which we also saw in the dashboard. So maybe it is a bad tube or something. Best of luck to a customer figuring that out without this type of measurement.
If we "only" allow 1% distortion and noise, available power shrinks to a trickle:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Max and Peak Power into 4 ohm M...png
Yes, that is only 2 watts!
Using 8 ohm tap, we get similar results:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Power into 8 ohm Measurement.png
Sweeping frequencies we see the typical rise in distortion with frequency. But also increase in distortion at low frequencies (transformer saturation?):
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Power into 4 ohm vs frequency v...png
I am showing both channels. Dashed line is the "good" channel.
Our power on/off test shows instability on top of noise at these events:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Power On Off Noise Measurement.png
Fortunately if you wait a minute or so, everything stabilizes:
Yaqin MC-84L Stereo Vacuum Tube Push-Pull Integrated Amplifier Warm up Measurement.png
The Yaqin MC-84L made a very positive impression on me with its modest size and super nice industrial design. And reasonable price for such tube products. Performance though, set a new record with respect to how bad it is, taking over the slot for the worst measured amplifier to date. The amp has 42 reviews on Amazon with average of 4.5 stars. Folks must be very tolerant of noise and distortion out there!
I do like the company honesty when it comes to power rating and even SNR.
Needless to say, I can't recommend the Yaqin MC-84L valve amplifier.
Specs:
Spec:
AC Voltage: AC115V and AC230V optional
Output Power: 2x12W(7ohm--8ohm)
THD:≤2%
S/N Ratio:≥80db
Frequency Response: 6Hz--90kHz
Input Sensitivity: 250mV
Input Signal Level:≤300mv
Max Power Consumption:≤90w
Tubes: 6P14x4pcs, 12AX7Bx2pcs
Net Weight:10kg
Features:
  • A High-Quality Tube Amplifier: Despite its affordable price, the Yaqin MC-84L amplifier is a remarkable audiophile-grade ultra-linear push-pull, full Class A tube amplifier.
  • Premium Grade Construction at a Fair Price:a majority of the components are of audiophile grade, produced by some of the best companies in the industry . MKP capacitor for reducing AC to DC voltage,famous Shuguang tubes:12AX7B, superior magnet wires on the transformer core,top-quality output transformer, high-quality volume potentiometer.
  • Impressive Sound: This amplifier delivers pristine audio quality, making it an exceptional addition to your sound system; Push-pull Circuitry: This design ensures minimal distortion, optimal efficiency, and high power output.
  • Powerful Output: It is only 12 watts per channel, but compared to transistor amplifier, it actually can output more than 60 watts.
  • Outputs: The amplifier can function as either a headphone amplifier (with a 6.3 mm headphone output) or as a high-quality tube amp capable of driving loudspeakers.
Hello Folks.
I find reviews of such products to be even more informative than usual.
It speaks volumes of how important is that we have ASR and how important the work of mr. Amirm (and other active members) is.
Now, forget about the flashy design of this amp and go become a forum donor!
Cheers.:)
We need an option below "Poor".
So, I got one of these amps over one year ago and got same bad feelings Amir's review highlighted.
It's nothing to write home, of course.
Sadly, there are so many half-priced EL34 amps, if well biased and benefitting of a point to point wiring, that performs way better.
Thanks a lot for this confirming review @amirm!
I went into this thinking, "bet this measures badly but it'll probably still be ok in the real world" ... then I read the review! That's pretty poor / broken!
Thanks for the review Amirm, I love the breadth of review information here and the opportunity to keep learning.
Does anyone know what an Amp like this actually sounds like - completely subjective - is it "tubey warmth" or hissy distortion and fuzzy clipping?
Subjective approach to these amps starts from a simple faith factor: pray to get at least 4-5 watts of not too heavily distorted power.
If this doesn't happen, the result is an amplifier that just sound meh.
