If you are talking about Gene's review on the RX-A6A, that 100 dB SINAD cannot be compared to Amir's because Amir did not do the same test.
Gene's 100 dB SINAD (0.001%) was obtained at the pre amp output at +1 dBV, that is 1 Volt rms, using analog input in pure direct mode. I agree that is good result, but it is not an apple to apple comparison with Amir's 81.8 dB SINAD was measured at the power amp output at 5 W, not the same tests at all. Also, as you already know, the two devices are different. If Gene measured the 3080, I suspect he would have gotten results similar to ASR's.
We bench tested the Yamaha RX-A6A 9.2CH 8K 150watt/ch Atmos/DTS:X Receiver to gauge power output and uncover performance issues we discovered. We discuss the proper settings for best power delivery.
www.audioholics.com
Thanks for your answer.
I thought the first test that Amir did is the pre out to test only the DAC.
Amir said "As usual, I started to measure the DAC portion by using the pre-amp output, only to be punched in the face by the AVR going into protection mode. "
In my test, I used the preout, was that wrong to test the DAC?
Should I have measured with a load at the loudspeakers? Then I don't understand Amir's comment that they should add an option to shut down the amps.
I mentioned Gene because I thought that the preout would always perform better than the test with a load at the loudspeaker output - or is that really not the case?
Sorry for all the potentially dumb questions...
Edit: I think I got it now! Amir mentioned the DAC test but only reported on the one with the 4 Ohm load. That test, I can unfortunately not do.
Fortunately, having a peak at 120 Hz is not the worst. Our hearing requires 25dB at that frequency, which means to reach the audible threshold, we would have to be at reference level volume and in a fully quiet environment. Unlikely to happen.
